Current  mirror using N-MOS 75N75
Old 21st June 2012, 10:31 PM   #1
muddasirwaheedmalik is offline muddasirwaheedmalik  Pakistan
Default Current mirror using N-MOS 75N75
I am using a module of 75N75 NMOS modules using the embedded circuit , the RE is 5 Ohm and VDD is 12 V, but changing supply voltage changes the Isink current as measured by voltmerer across the 12 volt 100 watt bulb as targert load.
My question is thatl is the current regulation for variable load in the mirror leg or the mirror leg also maintains the same current regardless of supply voltage variations,
if former is true then in my case the Iref is 2A via a 5 ohm Rref , if 2A is constant as Io then if i change load to 20 Ohm, voltage drop across it would be 2x20=40 volts which is >> VDD , how is it possible ?
Old 21st June 2012, 10:41 PM   #2
this is the schematic block diagram
Old 22nd June 2012, 06:34 PM   #3
franzm is offline franzm
Start here: Current mirror - Wikipedia, the free encyclopedia
Old 22nd June 2012, 07:44 PM   #4
Originally Posted by muddasirwaheedmalik View Post
.............. Isink current as measured by voltmeter across the 12 volt 100 watt bulb as target load........
How much does the resistance change?
regards Andrew T.
Current  mirror using N-MOS 75N75Hide this!Advertise here!
Current Mirror stinius Solid State 16 3rd January 2010 07:33 PM
Current Mirror: The V-mirror rtarbell Solid State 1 19th November 2008 03:27 PM
no current mirror, current mirror, cascoded current mirror, bjt or jfet VAS? maxpou Solid State 31 17th June 2008 05:31 PM
A special current mirror pjacobi Solid State 13 16th June 2008 05:16 PM
Current mirror abzug Solid State 7 1st January 2008 08:03 PM
Copyright ©1999-2017 diyAudio
