parasound hca 1000 blows fuses
Old 19th June 2012, 01:12 PM   #1
srinath is offline srinath  United States
Default parasound hca 1000 blows fuses
I have a parasound hca1000 that I picked up to work on.
The amp blows the 2 4 amp gma fuses on the left side at power up. The main fuse isn't blowing and the right side also is fine. It makes sound in 1 channel only obviously.
Has anyone had this happen and could point me to where the problem can lie ?
Thanks.
Srinath.
Old 19th June 2012, 03:16 PM   #2
Osvaldo de Banfield is offline Osvaldo de Banfield  Argentina
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
Do you know the approximate voltages and currents at this fuse. If do, place an incandescent lamp replacing temporarily the fuse, the see the lamp bright: if there is a sudden flash, a continuous bright, etc. This will give U a first idea of the issue in your set.
Osvaldo F. Zappacosta. Electronic Engineer UTN FRA from 2001.
Argentine Ham Radio LW1DSE since 1987.
Old 20th August 2012, 10:36 PM   #3
learnaudio is offline learnaudio
Default THE SAME PROBLEM WITH ME.
HI EVEREYONE. I HAVE PARASOUND 1000 HAS SAME PROBLEM. AND I STILL DON T KNOW HOW FIX. EXPERIENCED MAN, PL HELP ME TO FIX. THANKS ALOT.
Old 20th August 2012, 10:39 PM   #4
THANKS MR OSVALDO DE BANFIELD.
CAN U SHOW ME CLEARLY HOW FIX IT? THANKS A LOT
Old 21st August 2012, 05:09 AM   #5
john curl is offline john curl  United States
john curl's Avatar
Needs major repair. Probably broken output transistors.
"Condemnation without Examination is Prejudice"
Old 21st August 2012, 06:13 AM   #6
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
posting in all caps is like shouting.....it is rude....please don't do that again....
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 23rd August 2012, 07:57 PM   #7
im sorry about that. honestly, my english is limit. bros have a good day.
Old 3rd September 2012, 10:12 PM   #8
hi experts. can u help me? i hooking up with one channel now. sound so pour. thanks
Old 3rd September 2012, 10:26 PM   #9
lanchile is offline lanchile  United States
lanchile's Avatar
it can be a few problems, the first thing I would do is check the output transistors of the broken channel. DO THIS ONLY IF YOU KNOW WHAT YOU ARE DOING: other way leave it to a qualify person.
PS: even though some amps are unplug they "still" have some high voltages ( charged caps) work on your amp ONLY if you know what you are doing!
parasound hca 1000 blows fusesHide this!Advertise here!
FS: Parasound HCA-1000 THX 2-CH Power Amp mrdon Swap Meet 2 28th April 2013 05:25 PM
parasound HCA-1206 (Tony at Parasound.com) ostie01 Solid State 1 10th July 2012 05:24 AM
Parasound HCA-1000 upgrade Skorpio Solid State 15 11th August 2010 06:47 PM
Parasound HCA-2200 II Fuses movinginstereo Solid State 0 3rd December 2009 03:31 AM
For Sale: Parasound HCA-1000 2 Channel Amplifiers mhealy4998 Swap Meet 2 9th November 2009 10:28 PM
