Hafler 9505- Bias adjustment - diyAudio
Old 16th June 2012, 04:15 PM   #1
Default Hafler 9505- Bias adjustment
I'm going to be replacing two output MOS-FETs in my left channel(Q48/Q52), with Hitachi devices. Will I need to re-bias the outputs in that channel? If so- a little guidance, please.
Old 16th June 2012, 11:37 PM   #2
OK- I needed to search a bit farther online. Got my answer! To adjust the bias, disconnect the input and speakers and remove
the B+ fuse for that channel. Connect an amp meter across the now vacant fuse clips and adjust R45 (R145 for the left
channel) to get a current reading of 300mA for the 9303, 400mA for the 9505.
anyone got a hafler 9505 schematic? lt cdr data Solid State 21 21st July 2015 01:14 PM
Hafler 9505 amp Help SineWave305 Solid State 2 29th December 2011 07:33 PM
Help with Hafler 9505 AR2 Solid State 32 11th June 2010 02:56 PM
Hafler 9505 turn off thump AJ Solid State 7 3rd March 2008 04:30 PM
hafler 9505 circuit here! lt cdr data Solid State 7 11th June 2006 03:22 PM
Copyright 1999-2017 diyAudio
