Class A amp with fully symmetric design using only NPN output transistor
Old 16th June 2012, 02:00 PM   #1
muddasirwaheedmalik is offline muddasirwaheedmalik  Pakistan
Default Class A amp with fully symmetric design using only NPN output transistor
Hi i intend to make a 200-600W pure Class A amp.
My limited knowledge has limited to ouput device matching.
My best shot is a stock of 2SC5200 transistors.
Is there any simple design for class A pull push type using only NPN in output stage?
Reason:available 5200 transitors, 48 of them and no dismilarity in turn-0n turn off time associated with complimentary pair.
regards
Old 16th June 2012, 02:57 PM   #2
DouglasSelf is offline DouglasSelf  United Kingdom
DouglasSelf's Avatar
regards
It is perfectly possible to make a push-pull Class A amp with only NPN output devices. You simply use a quasi-complementary output stage, preferably with a Baxandall diode to reduce distortion.
You will find more info in my power amplifier book, (5th edition) page309.
The Audio Power Amplifier Design Handbook
Douglas Self
Old 16th June 2012, 02:59 PM   #3
sgrossklass is offline sgrossklass  Germany
That'll be a fabulous room heater.
Not to mention exceptionally big and heavy.
Here's an output stage variation for the Leach amp:
... as discussed here.
Q14/15 would be medium power, Q16/17 5200s, and Q18/19 plus corresponding Rs would be replicated in parallel, again with 5200s. Not sure how many you can realistically drive, 4 or 5 pairs seem common - maybe twice that max.
Old 16th June 2012, 03:07 PM   #4
Any schmematics , minimal parts, only symmetry CLASS A. ?
Old 16th June 2012, 03:15 PM   #5
If you are going to use only NPN output devices, then the "symmetry" bit is going to be real challenge.
Symmetrical is not necessarily good.
Douglas Self
Old 16th June 2012, 03:32 PM   #6
knutn is offline knutn  Norway
For 600 W output power (8 ohms), your push pull amplifier will dissipate more than 1200W, have a quiescent current of more than 6 Amperes, and the power supply rails will be more than plus/minus 100 Volts. I really look forward to see your well-sounding oven....
Old 16th June 2012, 04:01 PM   #7
qusp is offline qusp  Australia
qusp's Avatar
this is something like what a 600W Class A amplifier will look like, if you are lucky =)
Dimensions : 19" Rack Mountable 5U high (220mm / 8.7")
Overall Depth : 545mm (21.4")
Front Panel & Handles : 75mm (3")
Rear Handles : 40mm (1.6")
Amplifier Body : 430mm (16.9")
Weight : 40kg approx.
this is a 4 way amp though, with crossover and is 850w
Specifications
Output Power (RMS) :
HF: 100 Watts into 6 ohms
MF: 200 Watts into 16 ohms
LF: 275 Watts x 2 into 8 ohms
Old 16th June 2012, 04:15 PM   #8
pieter t is offline pieter t  Netherlands
This one (19" - 5U) is for a project to come, but it will handle not much more than 2 x 60 watt class A.
I am curious why, and for what purpose, people intend to make a 200-600 watt class A amplifier.
I guess the OT means class A/B
Old 16th June 2012, 04:36 PM   #9
qusp's Avatar
Originally Posted by pieter t View Post
This one (19" - 5U)
i'm curious too, my guess is hes not aware of exactly what the implications of that is, thus my including a picture of 1 channel
perhaps hes building something like these?
Old 16th June 2012, 04:47 PM   #10
Insane
But large speakers can be high efficient and play great music with low power tube amps...
Class A amp with fully symmetric design using only NPN output transistorHide this!Advertise here!
output coil design for class-d amp??? sweetperfume Class D 2 21st May 2012 10:35 PM
Possible to design a high-power class D amp with a low output impedance? 454Casull Class D 2 23rd February 2009 08:33 PM
MOSFET or NPN for class A output stage AudioGeek Solid State 30 25th July 2008 08:34 PM
Leach amp blowing NPN output transistor! supernet Solid State 3 29th June 2002 12:54 PM
