Do you like listening to distortion?
Old 16th June 2012, 02:50 AM   #21
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Originally Posted by bigwill View Post
I'm always shocked at how inaudible low order distortion can be. I try to get distortion as low as possible, but it's amazing how undistorted a pair of EL34 tubes wired as UL sound WITHOUT global feedback. The problem is of course the lack of damping, so you get a massive tonal shift from your speakers.
Lack of damping is just a poor way of saying current amp. If you are going to use a currnt amp, then you should build speakers that work well woth current amps (ie have a very flat (or complementary to the FR) impedance curve.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 16th June 2012, 06:34 AM   #22
CBS240 is offline CBS240  United States
CBS240's Avatar
Distortion? No thanks. I belive music reproduction should have as little distortion as possible. This goes for much more than just THD....allthough it sells well, THD by itself for the most part is meaningless.
This is why I made this amp...here. see attachment
All the trouble I've ever been in started out as fun......
Old 16th June 2012, 09:38 AM   #23
sbrads is offline sbrads  United Kingdom
Our hearing produces distortion which is quite easy to perceive with a few simple tests, so it always surprises me that we know when an audio system is clean and working well. Ear distortion can be measured, and is used for testing babies' hearing, the absence of distortion signifying a possible problem.
Old 16th June 2012, 10:48 AM   #24
fpitas is offline fpitas  United States
As was pointed out above, some types of distortion are more evident than others. I assume the brain can distinguish the "non-resident" distortion, at least to some degree depending on the listener.
Certainly in some cases the distortion becomes obvious mainly in its absence. Going from my old horn amp to the J2, the change was obvious. The midrange lost a "brightness" that I hadn't realized was there, and micro-details of formerly familiar material became audible. Lyrics became easier to make out, and in complex music with many tracks, it became easier to hear all the layers instead of a sonic smear.
I'm guessing a lot of these improvements are because the J2 is class A, and avoids crossover distortion at the particularly low outputs the horns need.
Old 16th June 2012, 09:25 PM   #25
I think the worst distortion in amps is some sort of 'hash' that you can't hear in itself but it just masks subtle musical clues. E.G. better rectifiers and using snubbers can work musical magic but it isn't harmonic distortion or intermodulation between audio frequencies that get fixed, I'm sure. When the hash goes you notice it but you probably didn't realise it was there in the first place. You just get to hear more music.
Old 16th June 2012, 09:38 PM   #26
That's a good description of what went on in my case, although I think it was mainly the crossover distortion of my former class AB amp creating intermod that was the guilty party. Horns in particular are a difficult load for a normal amp since they need about 20dB less power than a normal speaker. The amps are not designed for that situation, and crossover distortion that might be inaudible for a direct radiator becomes quite audible from the horn. Of course, there may be more to it, and the particular forms of distortion that inevitably remain (say, whether it's a JFET or bipolar amp) may contribute to the overall quality of the sound.
Old 16th June 2012, 10:04 PM   #27
Xoc1 is offline Xoc1  United Kingdom
Xoc1's Avatar
I have just acquired an amplifier that was rebuilt by Ben Duncan
Ben Duncan Research
It has very low distortion, The sound is very dymamic and detailed,
Ben takes a holistic approach to amplifier design - I think most DIY audiophiles would be surprised by the amount of care he took to avoid RF getting into the amplifier.
In the past I have noticed the sound of my audio system has been effected by other electrical devices left on in the room. RF is probably to blame for this.
Old 17th June 2012, 03:05 AM   #28
Jay is offline Jay  Indonesia
Banned
From below 3 graphs, which one is your option? Not everyone will 100% sure with their choice...
Old 17th June 2012, 03:26 AM   #29
frugal-phile(tm)
planet10's Avatar
Except for the 2nd, 1 & 2 are the same. 2 probably sounds better since it has a monotonic decrease as order goes up.
dave
Old 17th June 2012, 04:44 AM   #30
gootee is offline gootee  United States
Ben Duncan Research
I would be very interested in hearing what he did to try to prevent RF from getting in.
I have been preaching about the evils of RF incursion, here, for years. RF can be insidious. It gets rectified by PN junctions. Sometimes it could cause a sound at an output but maybe instead it just changes DC operating points of transistor circuits, maybe somewhere deep inside an IC.
And everything is an input, for RF. I also noticed that things like Magnepan planar speakers make great RF antennas. So into the output it goes, and backwards around the feedback loop and into the input. The crowd at the planar speaker asylum swears by the use of 10 uH high-current RF chokes, for example. Apparently with certain RF-susceptible amplifiers they deliver a clearly-audible improvement.
Do you like listening to distortion?Hide this!Advertise here!
What are you listening to? MikeW Pass Labs 36 20th June 2011 01:54 AM
Audibility of Distortion Listening Test...FUN! MJL21193 Everything Else 57 20th February 2008 09:13 PM
Non Linear Distortion testing - Harmonic Distortion JMB Multi-Way 0 20th July 2004 02:54 PM
