Suggestions for mono block amplifier?
Old 12th June 2012, 07:02 PM   #1
Duco is offline Duco  Netherlands
Default Suggestions for mono block amplifier?
Dear All,
I just finished my first amplifier ever. And it sounds wonderful to my opinion It's based on the L12-2 amplifier board often offered on ebay.
But I still got some transformers and capacitors left:
2* 300VA 2x22V transformers
4* Mallory 17000MFD @ 40V
4* (oversized) Sprague 50000MFD @40V
8* Philips 15000MFD @ 40V
I was thinking to build a set of mono block amplifiers, not too fancy but nice enough for my monitor audio RX2 speakers. Can some one help me point out some amplifier kits? I am still a rookie so i don't think I can handle a build completely from scratch.
Hope you can help me
-Duco
Old 12th June 2012, 07:19 PM   #2
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
22Vac/300VA isn't tempting for Class AB.
(is for a balanced design, but that's not rookie territory)
Transformers and caps say Class A, so says the RX2.
Easy to build with off the shelf PCBs : Cascoded F5, CViller's boards in the store.
Why does it hurt when I Pee ? (Ay Ay Ay https://www.youtube.com/watch?v=w5fLGWrHouk)
Old 12th June 2012, 09:20 PM   #4
Just stumbled upon these:
FL A1000 30W+30W Class A MJ15011 15012 Amplifier boar | eBay
Hiraga super 30W class A amplifier kit ! | eBay
I like the first one, for some reason I've got a some fetish for TO-3 transistors..
But eventually it's all about the sonic properties of the amplifier...
In my eyes all amplifier a somewhat qualified, but I'm not sure about the working voltages. With a rectifier and a 2* 17000MFD Mallory capacitor bank I get +/- 32V. So what is a wise decision?
Old 13th June 2012, 12:20 AM   #5
audiostar is offline audiostar  United States
How about SKA GB150 or GB300 ?
Old 13th June 2012, 12:37 AM   #6
Second that, Mr Ball's is not half bad for it's simplicity.
(me did a GB50D in full Class A with 25Vac Amplimos)
Old 13th June 2012, 01:46 AM   #7
Bigun is offline Bigun  Canada
Bigun's Avatar
my vote goes for a JLH 1969 Class A amplifier. Last time I looked there were pcb's and kits available on ebay. Here's an example from a seller with 100% feedback rating:
http://www.ebay.ca/itm/2pcs-High-qua...ht_3494wt_1413
The circuit is simple and elegant - learning about how it works is worthwhile.
The Class-A Amplifier Site
It's capacitor coupled output so built-in speaker protection. If you use 2N3055 power output transistors they should be easy to find at a reasonable price and you shouldn't have to worry about amplifier stability/frequency compensation since they are relatively 'slow'. The amp has an excellent reputation for sound quality.
The Hiraga amps are also excellent, but I believe they are more prone to power supply hum at the output.
With any Class A amplifier you'll need to get some heatsinks. They will need to be large. But they don't need to be fancy so look around for eBay options.
and I'm willing to follow my own advice - I'm currently building a dual-mono JLH 1969 myself.
It's one of the most popular amps of all time and there's a long standing thread about it here: JLH 10 Watt class A amplifier
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 13th June 2012, 11:56 AM   #8
I have looked at all results so far and narrowed my options:
This ones should work perfectly on +/- 32V without adjustments right?
MX50X2 Class AB Power Amplifier Board AMP Kit 2-Channel | eBay
And the SKA GB150
I don't have a ridiculously high budget, so i'm wondering what is wisdom..
Old 13th June 2012, 12:53 PM   #9
wahab is offline wahab  Algeria
This one should have the best perfs of the three mentionned
in the post above.
Besides , the guy give the schematic , wich show a classic topology
that perform well, yet it can be improved with very few typical mods
that you can fish in this forum not counting that depending of your
heatspreaders it can be biaised in class A.
Old 13th June 2012, 01:53 PM   #10
in the post above.
Allright. How "in short" can I modify it to run in class A? Is it better than the SKA GB150? I read good things about them..
-Duco
Suggestions for mono block amplifier?Hide this!Advertise here!
The SSE as mono-block akimmet Tubelab 3 14th January 2012 03:28 AM
2 x Helder HIFI TK2050 Mono Block Amplifier + SMPS 24V 5A Power Supply UK chet84 Swap Meet 1 19th July 2011 10:42 PM
How to choose a mono block amplifier? Jacky Cheung Solid State 3 21st June 2010 04:41 AM
2 Bogen 7027 tube amp vintage amplifier mono block karma Tubes / Valves 10 13th June 2005 08:30 AM
Mono block restoration soundfan Tubes / Valves 6 29th January 2005 01:27 PM
