All P-channel Regulator For TSSA Split Supply?
Old 13th June 2012, 05:24 PM   #21
RJM1 is offline RJM1  United States
Thank you Nico. I will also quote my second paragraph from post 12. "Itís not a problem if you are using a single negative supply and you do not want to use the unregulated supply.". As in if you have two unconnected secondary windings or two transformers.
Old 14th June 2012, 03:16 AM   #22
Jay is offline Jay  Indonesia
Banned
Okay then I believe it means that it is okay to go with the first post's circuit. Thanks everyone.
All P-channel Regulator For TSSA Split Supply?Hide this!Advertise here!
Split-supply to single-supply conversion? Khron Solid State 12 5th May 2011 12:06 PM
Wiring a subwoofer and split for one channel waksie Multi-Way 2 19th July 2010 08:40 AM
100 volt 10 ampere dv voltage regulator for split supply livenicely Power Supplies 0 19th November 2009 12:17 PM
Dual supply for LM1875 split supply dovganj Power Supplies 30 6th November 2009 03:19 AM
printer single supply becoming split supply? facundonu Power Supplies 2 16th November 2006 06:09 PM
