What is the problem of using the same transistor regulator for both positive and negative supplies?
Mosfet complementary pairs rarely have good complementary characteristics, but such regulator as attached is rarely used. Why? |
#3 |
Hi Jay,
personally I will only regulate the front end and driver stage of the amp, it makes for a far less problematic design and the end results remains excellent. Besides you do not create another heat source.
Kindest regards Nico |
#4 | |
With bipolar we can choose many fast device, and the level of complementary is high (NPN and PNP match well). Not so with mosfet. Even with smaller mosfets. |
#5 | |
Actually, instinctively I prefer to regulate the front end only, especially if the bias is not so high (here it is 2A). The problem is then the front end will have lower voltage (unless 2 secondaries used), which is not suitable here (I mean no success try in my case). And I have prepared to use high bias with TSSA. It has a very good chance to be the best amp. It outperforms F5 in almost all area. Where this excels is in power (that's why I prepared for high bias). F5 cannot go high power without excessively increasing distortion (read: F5 Turbo), but TSSA can. |
#6 |
The 2 N-channel MOSFETs would required to be closely matched, to prevent current-hogging.
Sam |
#7 | |
IRFP460 is a 20A 250W device. No problem with using only one device for any class-A amplifier. By paralleling I'm looking for better trans-conductance, not power handling. Correct me if I'm wrong, I'm not worry with destruction due to thermal runaway, because one device is capable of handling all the heat. What I'm worry about is the unbalance transconductance between positive and negative rail. I simulated 1 mosfet on the positive rail and 2 mosfets on the negative rail, and the result is much much worse than just using one mosfet for both rails. So I guess I will stick with using only one mosfet per rail. |
#8 |
[/QUOTE] Actually, instinctively I prefer to regulate the front end only, especially if the bias is not so high (here it is 2A). The problem is then the front end will have lower voltage (unless 2 secondaries used), which is not suitable here (I mean no success try in my case).
And I have prepared to use high bias with TSSA. It has a very good chance to be the best amp. It outperforms F5 in almost all area. Where this excels is in power (that's why I prepared for high bias). F5 cannot go high power without excessively increasing distortion (read: F5 Turbo), but TSSA can.[/QUOTE] The most important thing about regulation is to keep both rails at the same voltage. It does not matter very much if the absolute value changes... as long as both supply voltages change by the same amount. This can be assured by placing a very large value capacitor Between the + and - supply rails. Differential changes will be cancelled. This is especially useful in power amplifier output stages. I have been doing this for almost 20 years. -RNM |
#9 | ||
NP, if I'm not mistaken, mentioned the effect of this capacitor (from -V to +V) is increasing the effective capacitance (thus better filtering)? What I have seen is that the effect of this capacitor can be positive but can be also negative. But... I just simulated this and indeed it has good effect, thanks. |
#10 |
The problem that I see with this arrangement is that the negative rail and the negative regulated supply do not share the same ground.
| Split-supply to single-supply conversion? | Khron | Solid State | 12 | 5th May 2011 12:06 PM |
| Wiring a subwoofer and split for one channel | waksie | Multi-Way | 2 | 19th July 2010 08:40 AM |
| 100 volt 10 ampere dv voltage regulator for split supply | livenicely | Power Supplies | 0 | 19th November 2009 12:17 PM |
| Dual supply for LM1875 split supply | dovganj | Power Supplies | 30 | 6th November 2009 03:19 AM |
| printer single supply becoming split supply? | facundonu | Power Supplies | 2 | 16th November 2006 06:09 PM |
