Sherwood RV-8070R
Sherwood RV-8070R
Old 11th June 2012, 12:21 PM   #1
Carlosraj is offline Carlosraj  United Kingdom
Default Sherwood RV-8070R
Hi Friends,
I am having a problem fixing a sherwood RV-8070R AV amplifier. There is no sound from both the A and B Front Speakers. The centre speaker and rear speakers are working fine. I opened up the output board and found that all the output and driver transistors are OK.The front display is working fine. I can see only one relay which is meant for switching the power supply. The front, centre and rear speakers do not have any relay. Are the front speakers switch on by the microcontroller. Pls help.
Carlos
Old 30th May 2014, 06:53 AM   #2
joaomsilva is offline joaomsilva
I'm having the exact same issue. Did you manage to sort it out in the end?
Sherwood RV-8070RHide this!Advertise here!
Troubleshooting Sherwood RV-6010R surround reciever PSU AMelbye Power Supplies 1 1st April 2017 09:36 AM
Luxman Av Receiver Rv-357 elec972 Solid State 1 26th October 2015 03:37 PM
camper/RV hifi F.A.S.T Tachyon Multi-Way 2 6th June 2012 01:39 PM
Sherwood rv-8070r transistor help (sanken) sketchone Chip Amps 2 30th May 2011 04:43 PM
! Schematic needed ! for Sherwood rv-5050rds Brage Parts 0 18th February 2005 12:59 AM
