diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Solid State (http://www.diyaudio.com/forums/solid-state/)
-   -   Tekko dreams up another poweramp (http://www.diyaudio.com/forums/solid-state/214259-tekko-dreams-poweramp.html)
Tekko 11th June 2012 09:32 AM
1 Attachment(s)
I just dreamt up this amplifier, based on the Sony/Apex topology with the fully symmetrical IPS, but with a triple deep darlington output stage similar to that of the Leach Low TIM amp.
It simulates 0.00381% THD at 20kHz at a RMS power of 200+ watts into 4 ohms, with a phase shift of only 0.64 degrees.
The DC offset with the values shown is about 32mV which is acceptable, bias is about 60-70mA per output pair.
The first draft schematic:
vedmitraa 11th June 2012 10:48 AM
Hello Mr. Tekko,
Can you please send spice file or multisim file of this amp.
regards.
Vedmitra Sharma
AndrewT 11th June 2012 11:53 AM
I do not see Leach Lo Tim in there.
Why only 200W+ into 4r0 from 4pr output stage on +-60Vdc supply rails?
Did you mean to type 300W+?
Tekko 11th June 2012 12:11 PM
The 200W was based on the only transformer i have that gives me 60V rails.
However i realized minutes after posting this that VAS was dissipating almost 5 watts and the IPS around half a watt.
After correcting this and getting the offset back down to 30mV or less, THD had risen to 0.4%
so it needs some extreme work.
AndrewT 11th June 2012 01:43 PM
200W into 4r0 requires an output of 40Vpk and 10Apk.
Into a 4ohms speaker expect transient currents to approach 30Apk.
You shouldn't need +-60Vdc supply rails to get to those targets.
Nico Ras 11th June 2012 06:50 PM
Along the lines of an old KRELL KSA50 but with CCS in the input. Once optimised it should sound good. Complimentary symmetrical amps sound somewhat clinical but I like that kind of cold characterless sound.
Just on brief inspection, I would increase R9, R11. Reduce the input pair's current somewhat and increase R10, R12. Decrease values of C1, C2 and maybe add a cap across R18 to extend phase margin.
Nico Ras 11th June 2012 07:04 PM
Maybe cold and characterless was the wrong choice of words, but I think you know what I mean. It is opposite to warm lazy SE class A kind of sound. This amp sounds particularly nice when over biased a bit - say 2 to 4 watt or so.
Resources saved on this page: MySQL 18.75%
