just found this awesome site i have a question about a 6 channel amp board i salvaged from a home receiver and i am attempting to get it going i have a good idea how to hook it up but i don't want to accidentally let the magic smoke out of the chips i am thinking i just supply the voltage to the board and connect the inputs and connect the speakers using the supply ground.
the donor amp was a rca rt2280 /w logic board issues i am hoping to just make a custom power supply (+30v / -30v) and a car subwoofer style case. mike |
#2 |
after messing around with it for a bit i decided to just build a power supply with components off of the main board and this is what happened, not to shabby for my first audio salvage
the specs are 50w x 6 channel for a total of 300w , it smoked a 6ohm by 30W polk speaker (much louder than i anticipated) volume control will be done with the htpc Todo add relays to power it up with the htpc build a case in closing to all the people with a rca RT2280 that has the shutdown issues it 95% the time logic-board issues and with some simple soldering skills and a little technical knowledge the receiver can be retrofitted to a 6 channel amp for use with a external decoder with the only downside if you can call it that being each channel will now amplify the raw signal, so if you put a signal in with a lot of bass and you have a satellite hooked up chances are you can kiss the speaker goodbye like my polk speaker did |
#3 |
yep - good cheap project. Have you thought about packaging yet?
"You can keep your insurance baby nothing is guaranteed" -Tom Petty |
#4 |
i am going to use 1/4 inch ply board and cover it in sub-woofer carpet like you would find in a car, eventually i am going to get a htpc case large enough to integrate the amp and just leave the heat sink sticking out the back
| 7.1 or 5.1 TK2050 8-channel amplifier board | col | Class D | 2 | 27th October 2011 09:58 PM |
| 4 channel amp board?? | sideways | Class D | 6 | 8th February 2011 07:25 AM |
| Channel switching / Relay / board | diaz028 | Tubes / Valves | 4 | 12th September 2009 03:30 AM |
| One channel board for Adcom GFA-7000 | pablo170 | Parts | 1 | 23rd March 2006 01:10 AM |
| N-Channel Amp : Populated Board | Samuel Jayaraj | Solid State | 0 | 25th February 2002 12:21 PM |
