Mains seperation on PCB
Old 13th October 2003, 06:03 AM   #11
li_gangyi is offline li_gangyi  Singapore
li_gangyi's Avatar
Yeah...I'll second the no mains on PCB thought...seems dangerous...but many intergerated amps do it...and they are horrrs...not fingerproffed...of course they are not meant to be open and many have got a warning stated behind...but for the morons like us...
Kids in the back seat cause accidents...Accidents in the back seat cause kids...
Old 13th October 2003, 09:17 AM   #12
kiwi_abroad is offline kiwi_abroad  New Zealand
kiwi_abroad's Avatar
Excellent advice, thanks everyone.
It turns out the layout was a bit simpler than I expected. All of the traces are on the underside of the board, thick, short and well seperated. I had planned a MOV from the start, and the 'fisch paper' (I think I know the stuff you are referring to...) is a good idea and will be used.
The only last concern I have is the only live part left accessible to fingers (actually, MY fingers) is the fuse holders. Can I get PCB mount, fully insulated fuse holders?
Oh, regarding the MOV, am I right in thinking it should be placed after the fuses, so if it is triggered, the increased current will blow the fuses?
Adrian
Old 13th October 2003, 03:00 PM   #13
li_gangyi's Avatar
I guess you could get those with a little plastic shroud over them...slightly translucent...if you know what I mean...as for fuse placement...yeah...I think it should be placed after the fuse...
Old 13th October 2003, 04:06 PM   #14
peranders is offline peranders  Sweden
Electrons are yellow and more is better!
peranders's Avatar
Originally posted by janneman
What if lightning strikes?
I think the PCB between the tracks is much safer than having then on the same side even with 10mm separation, where there is always the chance of dirt, moisture etc.
According to my pcb supplier 1.6 mm FR4 can take 50 kV across the glass fibre.
No risk to have the mains traces on both sides but beware of the creepage distance via the edges (at the end of the pcb).
/Per-Anders (my first name) or P-A as my friends call me
Group buy: DCT03 DC trap for big toroidal transformers. Sign up for interest HERE. 41 pcb's in interest.
Old 14th October 2003, 07:34 AM   #15
peranders's Avatar
I forgot to mention that you should strive to have all "hot" traces so you won't be able to touch those, meaning that it's normally a good idea to have the traces on the solderside.
Old 15th October 2003, 04:32 AM   #16
I've decided that the fuse holders will be the type that mount on the rear panel and you unscrew a cap to get access to the fuse. This removes the last of the problems with 'accessibility to the dangrous stuff'. All remaining mains voltages on the PCB are on the underside.
Just for interest, the reason I'm doing this is I'm building a 4 channel Leach amplifier, and I'm implementing a soft start circuit. It has two relays and a power resistor, One relay switches on the mains power to the power transformers, but via the 15 ohm power resistor. 1 second later, the other relay bypasses the resistor, allowing full power to the transformers. The relays (and several other functions) are controlled by a PIC microcontroller. The relays are, of course, suitably rated for mains voltages
Adrian
Mains seperation on PCBHide this!Advertise here!
Pioneer A400 pre-power seperation advice needed metako Solid State 17 1st June 2009 12:28 PM
MAINS... simple, old style amplifier, plugged into mains electrical outlet (110) destroyer X Solid State 2 15th June 2008 02:31 PM
Problems with channel seperation jarros Class D 9 28th December 2005 06:52 PM
Mains Sockets? Tazzy Everything Else 7 1st December 2005 07:41 AM
No Full Stereo Seperation ..???? xitronics Everything Else 2 7th July 2005 09:25 AM
