Old 12th June 2012, 03:18 PM   #11
Tajzmaj is offline Tajzmaj  Slovenia
I'm afraid yes.
Did you check supply voltage at op amp? It should be +-15V. I don't know about 134 op amp but if it draws too much current...
Check datasheet or measure it. And be careful. Don't short something.
If noise bothers you it is possible to install some sort of dc protection using relay which act as power on delay as well. There is plenty of such ideas around. Just google it. Again ,,Bernd Ludwig,, text. It is a lot useful information there.
Cheers
Old 12th June 2012, 03:23 PM   #12
Just to make it easier.
http://www.desmith.net/NMdS/Electron.../405_Qw_14.pdf
Old 14th June 2012, 01:10 PM   #13
ClassA is offline ClassA  Taiwan
Thanks for all of your help,especially, Tajzmaj.
Now This 405 works fine and sounds good. I think the degraded op-amp might be the root cause.
Old 23rd June 2012, 02:07 AM   #14
noSmoking's Avatar
I bought a set of boards from Jim's Audio (quad 405),and have been reading what you guys have posted ,Any words of wisdom/changes before I turn on the Iron to build it?
Thanks for your help!
Old 23rd June 2012, 02:14 AM   #15
Hi ..
First one is Ludwig Bernd text for which I already posted link and the other is this one.
So check both and decide.
Cheers, Taj
QUAD 405 Amplifier Information and Modification
Old 23rd June 2012, 06:53 AM   #16
noSmoking's Avatar
Hi Tajzmaj,
I will indeed,
Thanks,
quad 405-2 goodguys Solid State 3 14th March 2011 09:35 AM
Noise with a modified Quad 405 vzs Solid State 9 26th September 2007 04:40 PM
Quad 405 Op-Amp Power Supply Thomo Solid State 6 19th July 2007 12:49 AM
Quad 405 strange noise post upgrade lance_the_boil Solid State 1 14th October 2006 09:36 AM
power supply capacitor upgrade on Quad 405-2 sberube Solid State 21 24th March 2006 07:05 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
