Anyone know what the advantages or disadvantages are of using two seperate 24v transformers as opposed to using one 48v centre tapped transformer. I'm using it to power a bridged LM3875 inverted subwoofer amp and I happened to have access to two 24v 10A trannies.
#2 |
looks like you have 480va total for the two trafos, u can use that for parrallel/bridge gainclone amp using 4 lm3886's....disadvantage, you have to mount two trafos instead of one.....advantage, you can make a separate +/- 35volt supplies not possible with a ct, type....
http://www.elab.ph/forum/index.php?topic=32688.0 |
#3 |
The one and only
All wattage figures adding up the same, you can get pretty
much the same results with 2 bridges (1 for each secondary) off of one larger transfer. pass - still alternating between Goldfrapp and Pirates of the Caribbean. |
#4 | |
Attached is the configuration of the amp/PS I have plagiarized from various sources. The amp is directly from National's application sheet AN1192. I built the PS and amp last night and how should i put it..I solved the PS problem. The amp, which I built verbatim heats up the "smallish" heat sink in about 4 seconds. Toasty. It also has a serious oscillation (motorboating). Starts low hz and increases. I have 2x1000 uF caps for each chip. Anything that jumps out as a potential problem? David
#5 |
Electrons are yellow and more is better!
1000 uF for each rail seems a little too little according to most people. You loose some power if the ripple is too high.
/Per-Anders (my first name) or P-A as my friends call me Tube Buffered Gainclone in work |Thread |
| Help identifying a pair of output transformers and power transformers | mjk130 | Parts | 3 | 30th January 2009 10:44 AM |
| FS: Transformers | alexcd | Swap Meet | 0 | 19th November 2008 08:34 PM |
| WTB : Transformers | korben69 | Swap Meet | 1 | 27th June 2008 06:05 PM |
| my first amp (transformers???) | fitchmicah | Chip Amps | 5 | 7th January 2007 07:26 PM |
| Back to Back transformers as Isolation transformers | mikee55 | Chip Amps | 2 | 17th March 2006 11:38 AM |
