Tweeter Class A Amp
Tweeter Class A Amp
Old 9th June 2012, 06:31 PM   #1
krassyg is offline krassyg  United States
Default Tweeter Class A Amp
I am looking to get or build a class a solid state amp for the tweeters and maybe mids of my Focal Utopia clones. I am currently using one of these for the quad amplification:
Onkyo PA-MC5500 - THX Ultra2 9-Channel Power Amplifier | Model Information | Onkyo USA Home Theater Products
What would be the best option that I have? I see a lot of 30W to 50W DIY Class A kits on ebay; are they any good? Would it be an improvement over my current amp?
Old 9th June 2012, 10:37 PM   #2
carlmart is offline carlmart  Brazil
At Nelson Pass site you should find an old ('80s?) 40w class-A amp project that many people used them for powering their tweeters until the late '90s.
That shouldn't have changed that much, as class A amps are still considered better sounding than all other classes. They are just not efficient, but at low power levels that shouldn't be such a big deal.
Old 10th June 2012, 03:28 AM   #3
bear is offline bear
expert in tautology
bear's Avatar
Tweeter Class A Amp
build, buy a kit, or DIY?
There are a few very nice DIY options, if you search here.
A bit depends on the sensitivity of your tweeter vs. the mid driver, and also the nature of your xover, plus the actual power handling of the tweeter... that will help determine what power range amp you need or want.
Also, consider a tube unit too... fwiw. Can sound wonderful done right.
The Pass forum and the First Watt site have some class A amps too...
_-_-bear
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 10th June 2012, 05:27 AM   #4
I am looking to buy a kit; I am not at a level that would allow me to build my own. I am good with a soldering iron and I do have the basic knowledge when it comes to electronic cirquits.
The tweeters and mids are the same used in the Focal Utopia EM. The crossover is a digital crossover built into the Onkyo TX-NR818; will upgrade to the pre/pro version when it is released in the fall.
Old 12th June 2012, 12:20 AM   #5
What would be the absolute best DIY kit that I can buy?
Old 12th June 2012, 11:48 AM   #6
Not that many "non-clones" class-A amp kits to pick from.
Get in contact with Audioxpress to see if they still have some Pass class-A kits left.
In the Pass forum might have info on that too.
There's also the JLH class-A amp around, but I'm not aware of any kits, maybe on eBay. Google that.
Old 12th June 2012, 11:50 AM   #7
Old 12th June 2012, 11:59 AM   #8
toprepairman is offline toprepairman  United Kingdom
You don't really need a massively powerful amp for the tweeters, and you won't notice any difference between class A or B. (JLH or Hiraga will be fine)
Build a class A for the midrange as that's where your hearing is most sensitive.
As a guide you want 150 Watts class B for the bass, 30 W class A for mids and 20W class B for the tweeters.
It can get more com[plicated than that as you can compare average versus peak power levels for the frequency bands where for the treble the ratio is very high, but for the time being try to keep it simple.
Old 12th June 2012, 12:01 PM   #9
wahab is offline wahab  Algeria
Neither JLH class A amp or Pass F5 style amps are suited to drive tweeters
since they have high distorsion ratios at high frequencies , quite higher
than usual AB class amps.
A good solution would be to use a proved AB amp kit and then bias it
in class A for the five first watts.
Old 12th June 2012, 03:06 PM   #10
R.I.P.
You don't need a lot of voltage drive for a 100dB/W tweeter in domestic listening.
You will need ~ double the voltage drive for a 94dB/W tweeter.
And double the voltage drive again, if you use an 88dB/W speaker.
From there I see two bits of information that must be researched:
What peak SPL will you expect from your tweeter?
What sensitivity will the tweeter have that you eventually want to drive?
Without that crucial data you and everyone else, can only guess.
regards Andrew T.
Tweeter Class A AmpHide this!Advertise here!
CLASS A TUBE AMPLIFIER FOR TWEETER lduarte1973 Tubes / Valves 22 5th May 2011 07:11 PM
Tweeter Mount & Diamond Audio Aluminum Tweeter cnp112 Car Audio 0 18th November 2010 05:35 AM
Configuring an AB class amp to work in pure A class jrme Tubes / Valves 5 23rd February 2010 06:31 PM
Can a Class AB PP amp be said to be operating in Class A at low signal levels? ray_moth Tubes / Valves 19 23rd January 2009 07:52 PM
Tweeter help for Miller & Kreisell Tweeter 17500 merajsalek Multi-Way 4 3rd September 2008 03:41 AM
