Power Supply ceramic caps burnt
Old 9th June 2012, 01:31 AM   #31
Clemford is offline Clemford  United States
I forgot to post the updated drawing of the input with the fuse, switch and cap across it. I put dotted lines where I think the MOV should go. Please correct me if I'm wrong. And would lead length matter since there's distance between the two ends?
Old 9th June 2012, 01:38 AM   #32
Michael Bean is offline Michael Bean  United States
Michael Bean's Avatar
Clemford,
No, a power-off thump is usually caused by the power supply caps discharging with the speakers connected, as in the speaker relay (if any) isn't working. The cap across the switch contacts is to minimize arcing of the contacts, although it may also reduce the popping noise associated with switch contacts.
Mike
Old 9th June 2012, 02:03 AM   #33
DigitalJunkie is offline DigitalJunkie  United States
Send a message via AIM to DigitalJunkie
For 120Vac mains,I usually see/use 130-150V MOV's. You want it a bit higher than the mains voltage,so it doesn't clamp constantly,but not so high that it lets all kinds of nasty spikes through. 300/500V is way too high,IMO.
Here's a couple suitable candidates
150V: V150LA10AP Littelfuse Inc | F3017-ND | DigiKey
140V: V140LA10AP Littelfuse Inc | F3016-ND | DigiKey
130V: V130LA10AP Littelfuse Inc | F3015-ND | DigiKey
Old 9th June 2012, 02:18 AM   #34
if that's the case, I think radio shack has them for a couple of bucks in store.
Old 9th June 2012, 02:42 AM   #35
theAnonymous1 is offline theAnonymous1  United States
theAnonymous1's Avatar
One thing I just realised is every amp I own that has a linear supply uses film caps for power supply decoupling. Not a single ceramic in sight.
Old 9th June 2012, 02:52 AM   #36
that's why I was wondering if I could use the mylar ones in place of them but I guess they are more for tone rather than filtering? Of all the schematics I found on line I don't think many put caps on the primary at all. Seems like they are more trouble than they're worth. I would think there's less chance of shorting the primary to ground without them.
i think that's the reason why Indiannajo said to use 1kv ones. Good insurance in my book if I decide to use them. I think when I get the replacement input jack i'll see how the amp performs without them though.
Old 9th June 2012, 03:09 AM   #37
Well, they aren't on the primary they're on the secondary.
Old 9th June 2012, 03:28 AM   #38
sorry about that. It's been raining for days here non stop and i'm getting dyslexic cabin fever. Reminds me of back in Boston. I meant to say before the bridge or at least it looks that way I think.
Power Supply ceramic caps burntHide this!Advertise here!
Preffered film caps to replace ceramic caps? rg12 Parts 20 2nd September 2010 04:35 PM
Power supply options.. bigger trafo with less caps or medium trafo with heavy caps? rhythmdiy Chip Amps 9 23rd October 2007 12:30 AM
200V ceramic caps AndrewT Parts 2 22nd April 2005 02:11 PM
Replacing ceramic caps - do or don't? Cradle22 Solid State 4 16th March 2003 12:39 PM
Replacing ceramic disc caps with silver mica caps? G Solid State 5 18th November 2002 01:02 PM
