Power Supply ceramic caps burnt
Old 7th June 2012, 02:36 AM   #11
Michael Bean is offline Michael Bean  United States
Michael Bean's Avatar
The one on the power switch is there to prevent arcing the switch contacts.
Mike
Old 7th June 2012, 03:55 AM   #12
Clemford is offline Clemford  United States
Originally Posted by davidsrsb View Post
Actually suppressing the switch contacts does make some sense, but I would still put across Live and neutral after the switch. It's probably failed open anyway so fit a new MOV of adequate rating.
The transformer has 2 wires on the primary. Should I put the varistor directly across the two and since it's 110 volts in what value should I use.
Old 7th June 2012, 04:01 AM   #13
Originally Posted by indianajo View Post
You might put a 300V or 500V MOS surge supressor on the input of the power transfomer. I like the 14 mm ones, they have longer life. PCAT power supplies usually have the 7 mm versions on the input, they are blue. I salvage 14 mm supressors from dead motor drives but distributors sell them. Instruments in parallel with a refrigerator or air conditioner get power line transients of 4-10x the nominal power line voltage when the motor turns off at the peak of the voltage waveform. A film cap will not surpress sharp edged transients from either motors or lightning surge due to the inductance- better stay with ceramic. Unless you buy an expensive stacked (non-inductive) film cap. Ceramic caps can be quite durable, but some manufacturers don't do enough incoming inspection tests on the bargain parts the purchasing agent finds. 104M is a 0.1 uf high voltage cap, I think above 600 but I don't have the chart. M is a voltage code. You don't show the rail voltage, but 600 v spikes are quite common on the input AC line. 1000 V ceramic caps don't cost much more, certainly not compared to the freight of the box from the distributor.
So it's best then to get a 1 kv ceramic disc cap rather than the gumball looking mylar radial film one's found on my guitar tone pots to replace the 104m's? Also, I thought the M was a tolerance code for 20%.
Old 7th June 2012, 11:33 AM   #14
indianajo is offline indianajo  United States
indianajo's Avatar
There is a military code that uses a trailing letter for voltage on caps. No telling what your cap manufacturer meant, but obviously the voltage performance was inadequate whatever the rating was. Buy 1000 V ceramics they are cheap compared to the freight bill.
For the MOS supressor, I find 300 V ones in PCAT power supplies designed for 120/240 VAC, and 500 V ones in motor drives for 460 VAC 3 phase. Most transformer wiring is suitable for 600 VDC, so I reuse 500 V supressors in my 120 V hifi equipment, but If I was buying new I would buy 300 V ones. Yeah, the varistor goes after the power switch and across the input of the power transformer (and anything else). I mount a Cinch terminal strip (solder type) up near the power switch to make a safe place for it.
Film caps are fine for tone controls for the 20-15000 hz human ear, but power line spikes can contain frequencies over 1 mhz (fourrier analysis) so the inductance of a wound cap is not suitable for suppressing those. 1000 V disc caps for across the transformer output, or X2 rated caps on the input if you want to get modern and UL/CSA/VD compliant . Disassemble a dead PCAT power supply and look how they do it these days. Not blowing up due to refrigerator motor turnoff spikes is useful even in a $29.95 commodity product. Your MOS suppressor should come with a UL/CSA/VDE logo, too.
As michael bean suggested, most high end equipment also has a .01 uf 1000 V ceramic cap across the power switch contact to eliminate turnoff pop. I installed those years ago in my dynakit equipment, following TV practice I saw on the Howard Sams prints, and when lightning strikes with power off it usually takes out the 1000 V turn off pop capacitor and also arcs over the slide power switch without damaging anything else. Just a nice extra you could order now at the same time as the other things.
Dynakit ST70, ST120, PAS2,Hammond H182(2 ea),H112,A100,10-82TC,Peavey CS800S,1.3K, SP2-XT's, T-300 HF Proj's, Steinway console, Herald RA88a mixer, Wurlitzer 4500, 4300
Old 7th June 2012, 08:55 PM   #15
michael was right. I looked at it and itis in fact a cap. It says 103 on it. I just assumed it was a varistor because it looked like one at first glance. I'll redraw the drawing with the switch and cap and where I think the varistor should be incase I'm mistaken where it should go. But these could actually plug into a wall socket then without damage? Thats basically what I'm doing then by putting it across the line in of the primary? I was thinking I could solder it across the terminals where plug comes in. It uses a computer type 3 pin IEC 320 C14 panel socket with a built in fuse. I could solder it on the backside of it. I'll also order a couple of ceramic disc 1kv caps at the same time as the varistor. Thanks btw for all the info in your reply . As always, this is the place to go for these technical questions. I've received great help as well in the tube/valve section.
Old 7th June 2012, 10:44 PM   #16
indianajo's Avatar
It is a bit more traditional to put your surge suppressor MOS devices after the switch and after the fuse or circuit breaker, then before the transformer or rectifier. Yes they have 120 VAC + spikes on them, that is what they are for. That is why UL/CSA/VDE rate them for the proper uses. I suggest drilling a hole for a cinch type solder terminal strip, to mount the mos suppressor on. That is how I usually do it. Tubesandmore.com, triodeelectronics.com, electronicsurplus.com, apexelec.com sell them, not mouser or newark. MOS supressor Varistors are blue and have an elongated S with 2 slashes through it on them. MOS suprossors will have a 3 digit number, which is the Voltage they are inactive to. Above that voltage they short out the spike, up to a certain rated energy.
Caps don't always have uf or pf on them, but usually now have a 3 digit number unless very precise 4 digit units. Caps often have a trailing letter for the voltage class, unless the voltage is shown explicitly in numbers with a V. To see all this stuff at look, cutting up a PCAT power supply is very instructive, it has all this stuff, which I recommend copying but stopping before the rectifiers into the DC storage caps for the switcher power supply. I even salvaged the toroid noise suppressor from a PCAT supply to put inseries with the AC hot and neutral line to keep RF from CB'ers out of my disco mixer I use instead of a preamp. The E-core transformer does that job on an old amp that still has one of those.
Old 8th June 2012, 05:53 AM   #17
I'm not sure what a PCAT supply is. so I googled it but couldn't find anything.
I also tried to find a .1uf 1kv cap. You would think they would be a dime a dozen, as well as the 600v MOS. I usually buy direct from China on Ebay so I'll have to check out your links. One thing I will be doing, at least while at my house, is running it through a Furman PL-8C.
Old 8th June 2012, 06:21 AM   #18
no luck on those links. I'll have to go hunting.
Old 8th June 2012, 07:31 AM   #19
theAnonymous1 is offline theAnonymous1  United States
theAnonymous1's Avatar
I think a 1000v rated ceramic is way overkill, which isn't a bad thing if you don't mind paying around $4 for each cap. Still pointless though.
Old 8th June 2012, 08:14 AM   #20
It seems like all the ceramic disc's are 50V. Very few are 100v. I think I'll try a couple of 50v that I have and try the MOS if I can figure out how/where to put it. Either that or I'll buy a power strip with surge protector for when I use it away from my Furman. I don't really care to start splicing up the wiring of the amp and I'm still not exactly sure where to put it. And a surge strip won't cost much more than a varistor by the time I end up finding a 600v ( I think I found a 1000v one on ebay but I dont know if it's ok to use ) one. It sure seems like it would be the simple way out. And like you said earlier, the caps are just for noise. It is nice to know, thanks to you guys, that it was probably just a surge that took out the caps in the first place and they were just probably 50v ones anyway.
Power Supply ceramic caps burntHide this!Advertise here!
Preffered film caps to replace ceramic caps? rg12 Parts 20 2nd September 2010 04:35 PM
Power supply options.. bigger trafo with less caps or medium trafo with heavy caps? rhythmdiy Chip Amps 9 23rd October 2007 12:30 AM
200V ceramic caps AndrewT Parts 2 22nd April 2005 02:11 PM
Replacing ceramic caps - do or don't? Cradle22 Solid State 4 16th March 2003 12:39 PM
Replacing ceramic disc caps with silver mica caps? G Solid State 5 18th November 2002 01:02 PM
Copyright ©1999-2017 diyAudio
