Need help with IC connection
Old 5th June 2012, 05:22 PM   #1
BillEpstein is offline BillEpstein  United States
BillEpstein's Avatar
Default Need help with IC connection
I have 2 ICs, one 2x12 the other 2x10, each appear to have 3mm spacing. I need to solder or crimp wire to them. I'm looking at Digikey for something to plug them into that I can connect to but don't really know what I'm looking at.
There's no PCB, just the chips themselves. TIA, Bill
Old 5th June 2012, 05:40 PM   #2
whizgeek is offline whizgeek  Ireland
its 2.54mm or 1/10th of an inch for standard thro-hole DIL ICs.
chip sockets or header sockets. turned-pin are the better type overall.
Google Image Result for http://media.digikey.com/photos/Mill-Max%20Mfg%20Photos/801-43-020-10-012000.jpg
Old 5th June 2012, 05:46 PM   #3
jaycee is offline jaycee  United Kingdom
DIP packaged IC's ?? You can get DIP sockets which will work. For this particular application I'd suggest ones with turned pins.
Need help with IC connectionHide this!Advertise here!
search pcb with IC tl494 or other Ic to build a smps caraudio Ground Zero Car Audio 0 13th December 2010 04:58 PM
What is the difference between an isolated IC and a non-isolated IC? DJ Exprice Chip Amps 16 20th June 2006 06:34 AM
Copyright ©1999-2017 diyAudio
