diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Solid State (http://www.diyaudio.com/forums/solid-state/)
-   -   power section pops like frying bacon (http://www.diyaudio.com/forums/solid-state/213895-power-section-pops-like-frying-bacon.html)
Pbassred 4th June 2012 09:14 PM
I am attempting to repair a guitar amp that belongs to a friend of mine. I isolated the power section and power supply from the preamp and tone controls. Its making random pops and crackles as if I am wiggling a loose connection. The power supply is a simple unregulated bridge rectifier and 2 caps. The amp is a TIP35 and 36.
I have re-soldered all of the component connections and changed all of the electrolytic caps with no success. What you recommend next?
moschfet 4th June 2012 09:41 PM
Hi Pbassred,
this could be a cold solder joint.
Ian Finch 5th June 2012 12:21 AM
.....Or a deep-fried semi, assuming you have no sound. Did you have some output before dismantling?. If not, run a DVM over the base emitter junctions and verify there is ~0.6V across each. junction.
wg_ski 5th June 2012 02:45 AM
Highest on my suspect list would be the input transistor(s) of the power section. That is, the one that follows the tone/volume control section. That's where noise from a bad transistor or cold solder joint would bother it the most and be noticeable.
Pbassred 5th June 2012 06:26 AM
It works properly as an amplifier. I had already reflowed the solder joints so it can't be a cold joint. I'll swap the input transistors and see where that gets us.
indianajo 5th June 2012 11:41 AM
Although the other causes are more likely I am sure, I had a frying bacon noise (low) on both channels in a power amp from some tantalum input caps (5.0 uf) I installed. Caps were purchased at RK distributing, a local parts store. Had it from the day I activated the purchased dead amp until 20 years later when I replace the caps again. Wasn't any internet in those days, didn't know what to expect from a transistor amp. This replacement time I used 4.7 uf 50V CPO ceramic caps. Much better! Still have the OEM (original equipment manufacturer's) 1970 transistors on one channel.
sbrads 5th June 2012 01:29 PM
Freezer spray is good for helping to find such faults. Apart from joints and caps, don't forget resistors. I've seen lots of usually high value (>47k) resistors go dodgy after several years if the leads are bent close to the body.
DF96 5th June 2012 01:43 PM
Reflowing joints can make them worse, while at the same time hiding the evidence by giving them all a nice shiny appearance. Bad joints should be redone, the rest left untouched.
jitter 5th June 2012 04:17 PM
Perhaps this amp suffers from popcorn noise. If that is indeed the case, I would suspect a high gain circuit.
Ian Finch 5th June 2012 05:09 PM
I think that popcorn noise is intrinsic to the device. i.e it would have sounded that way from the time of manufacture.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
