SONY Is it really true? - diyAudio
Old 4th June 2012, 01:33 PM   #1
Default SONY Is it really true?
SONY stated its total power rating is 1000watt RMS
I can't believe this is it really true
DAV-DZ340K : DVD Home Theatre System : Home Theatre System : Sony India
Old 4th June 2012, 01:46 PM   #2
Banned
Probably not.
Home Theater testing is not the same as the old way for 2 channel stereos.
Example: Let's say they test one channel to ~200wpeak.
First of all, the 200w is not usable clean sound.
Second and far more important, they only have to test one channel at a time, not six. It is a loop hole.
Back when 2 Channel stereo amps were more common, they all had to go under regulated tests, or risk being pulled from the shelves. AFAIK it is still this way for 2channel. "Home theater" and all others do not follow under these guidelines.
Even if it was true, is it really all that impressive for an amp with 6 channels?
You need to find out what it has for a power supply, that may give you a better picture.
In most cases you realize the power supply is not strong enough to power ALL the channels to full power, just one at a time for "testing".
I suppose even Sony has to do this to stay competitive with other advertisers.
Old 4th June 2012, 01:56 PM   #3
chris661's Avatar
I'm fairly sure it'll stand 2 channels driven, in keeping with the requirements for stereo amplifiers.
Next up, the power figures are usually at 10% distortion. This is way past listenable - you could probably half those power ratings and get something much closer to the truth.
... the puny satellites won't stand much power either, so its lucky that the amplifiers don't put much out.
It's all seriously over-rated, fairly typical of average Joe sound systems.
Old 4th June 2012, 01:58 PM   #4
Nico Ras's Avatar
It certainly is possible, but not all at one time. They do not say all channels driven, so each channel on its own could be capable of outputting the claimed 170 watt, therefore they are not lying.
Kindest regards
Nico
Old 4th June 2012, 04:49 PM   #5
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
I don´t believe it is true. Here in Argentine, it is common to use the acronym PMPO (peak maximum power output???), and the true is that this value divided 300 is the real power at the speaker, in my experience measuring equipment in the Philco of Argentina several years ago. In example, a set of announced 1500W PMPO is really a 5-7W/channel at 10% THD. It is sufficient to see the rear of the speaker, and or the size of the heatsinks of the output stage, or the transformer´s weight.
If anything can go wrong, it will.
If anything just cannot go wrong, it will anyway.
Old 4th June 2012, 05:31 PM   #6
jitter is offline jitter  Netherlands
jitter's Avatar
Download the manual from Sony India and look at the specs. Quite creative:
Brazilian models:
all channels except subwoofer (SW): 142 W/ch @ 3 Ohms, 1kHz/10% THD;
SW: 140 W @ 3 Ohms, 80 Hz/10% THD.
Other models (rated):
all channels except subwoofer (SW): 108 W/ch @ 3 Ohms, 1kHz/1% THD;
SW: not specified
Other models (reference):
all channels except subwoofer (SW): 167 W/ch @ 3 Ohms, 1kHz/THD not specified);
SW: 140 W @ 3 Ohms, 80 Hz/THD not specified.
No specification of the measurement method. Also, the nominal impedance of the speakers doesn't seem to be specified.
The power consumption is rated at 160 W. I assume that is max. power consumption. Based on this I assume that the amp power ratings are peak power and not continuous power.
My guess... about 25 W continous power into 3 Ohms, maybe 10 W into 8 ohms per channel...
Old 4th June 2012, 05:34 PM   #7
RJM1 is offline RJM1  United States
Going from it's weight from the spec. sheet I'd say no. Main Unit Weight Approx. 3.5kg spec sheet DAV-DZ340K : DVD Home Theatre System : Home Theatre System : Sony Asia Pacific And the spec sheet does say RMS power. It's not taking my carriage returns, It's just running my words together!
Old 4th June 2012, 06:07 PM   #8
The size of those speakers are of 4 inches would they with stand 167W RMS power?
Old 4th June 2012, 06:11 PM   #9
Frank Berry's Avatar
Total power consumption of 160 watts says it all.
Frank
Old 4th June 2012, 06:36 PM   #10
CBS240 is offline CBS240  United States
CBS240's Avatar
They cheat. By using a seperate sub, they cut the bandwidth of all the other amplifiers. It requires much more headroom to have all the frequencies in one amplifier channel, that is a full bandwidth speaker cabinet with a crossover network showing a highly reactive load. I find it is harder to correctly put the signal back together after seperating it in such a way, it depends on your position relative to the speakers. I guess that is why they need a bunch of fancy signal processing. I'd say build a better amp, like they use to back in the day when Sony meant a quality product, but then I don't work for Sony.
All the trouble I've ever been in started out as fun......
IS THIS TRUE? mclsound Multi-Way 25 1st January 2012 04:46 PM
Is it really true!? humlan57 Full Range 10 11th January 2010 11:47 PM
is this true???? kathodyne Tubes / Valves 16 29th January 2006 11:26 AM
Is this true? josefr Digital Source 3 9th April 2003 10:28 PM
Copyright ©1999-2017 diyAudio
