Ovation e-Amp is Completed Ovation e-Amp is Completed - Page 6 - diyAudio
Old 12th June 2012, 11:12 AM   #51
Algar_emi is offline Algar_emi  Canada
Algar_emi's Avatar
Hi Bonsai. Do you have this amp pcb set available for sale? Thanks.
Old 12th June 2012, 01:11 PM   #52
Bonsai is offline Bonsai  Europe
Bonsai's Avatar
Hello Algar,
I am not planning to make his PCB available.
There are two other amplifiers in the works. A 15W Class A current feedback amplifier (the sx-Amp) and an 80 watt class AB current feedback design (the nx-Amp). These will be with full PCB layout and write-ups on my website for anyone to build. However, please note it will still be a few months. I like to build and test before publishing. Please be patient. Thanks for your interest.
bonsai
https://www.ovationhifidelity.com/ and DIY here http://hifisonix.com/
Old 12th June 2012, 01:53 PM   #53
Algar_emi's Avatar
Tx for the info.
Old 12th June 2012, 04:55 PM   #54
Nico Ras is offline Nico Ras  South Africa
Nico Ras's Avatar
Originally Posted by Bonsai View Post
Hello Algar,
Andrew, that is a novel idea, to build and test before publishing!!!
Kindest regards
Nico
Old 13th June 2012, 12:08 AM   #55
Bonsai's Avatar
Ha ha.
I want to make sure i don't make an *** of myself.
bonsai
Old 26th June 2012, 08:28 AM   #56
wahab is offline wahab  Algeria
Hi Bonsai
Here some sims of the original TEF step response as well as those
of a slightly modded version.
The idea of the latter is to reduce pre drivers agressive capacitive loading
by implementing a local miller loop , a solution find in many japanese amps.
The mod apparently reduce bandwith in small signal analysis , although
phase margin seems better by 15.
When checking the OPS in insulation , the modded version has in fact
better slew rate overall with more or less regular slope while due to
capacitive loading the original version exhibit a brutal reduction in slope.
The amplifier s step response with the two circuits , using only
two output pairs and 20R load :
Old 26th June 2012, 01:25 PM   #57
Bonsai's Avatar
Wahab, looks like you put quite some effort into these sims. The networks between the bases of Q19 and Q28 and their associated rails in the diagrams above are not Miller compensation networks. They are damper networks, which along with the rail decoupling between Q19 and Q2 and Q11 and Q28 (not shown in your diagrams above) are designed to ensure that a Colpitts oscillator structure is not formed with the external circuit inductances. R1 and R9 (3.3 Ohm resistors) also aid in ensuring there is no parasitic oscillation in the output stage. I need to photograph the square wave response and post this up, but there is no overshoot on the final amp - note that the input filter is also part of the compensation network.
When looking at the compensation design, loop compensation has to be separated from parasitic prevention. The root causes of oscillation in these two areas are different.
I do measure slew rate with the filter disabled, but I don't think you can look at overshoot with part of the comp network (i.e. input filter) disabled.
In my write-up, note that when testing for squarewave response into an 8 ohm resistive load, this should be done by connecting the load before the output inductor - there should be no overshoot under those conditions. Again, when driving a normal load with expected capacitiance, then this is done with the load connected after the inductor and you can then expect to see ringing due to the tank circuit formed by the output inductor and the load capacititance.
bonsai
Old 26th June 2012, 07:14 PM   #58
Nico Ras's Avatar
Hi Andrew,
What was the reason for your choice of input pair. Did you consider 2SC2240/2SA970 without the need of cascodes, or is there other advantages that I am missing perhaps.
Kindest regards
Nico
Old 26th June 2012, 10:29 PM   #59
Bonsai's Avatar
Hello Nico. I used 2N5550/5551 for the cascodes and 547/557 for the LTP's. I chose the 547/557"s because of their very high gain, but of course they are not rated for the 65V rail, and that's why I cascodes them.
You do get improved HF supply rejection with the cascodes as well.
Actually, the original proto used 5550/5551 without cascading, but I I struggled to select pairs near the upper part of the hfe range. There are no issues with this of course with the 547/557 pairs. I'll need to take a look at te types you mention - I have not used them before.
bonsai
Old 27th June 2012, 04:23 AM   #60
Bonsai's Avatar
Interesting Trannies Nico. Pd is 300mW so on 65V rails with 0.5 LTP current I am already dissipating 300mW, and on high output swing this will peak at over 600mW. (Another reason BTW for the cascodes was to limit the Pd in the diff amps)
bonsai
Ovation e-Amp is CompletedHide this!Advertise here!
Updates on my New Ovation SCA-1 pre-Amp Bonsai Solid State 2 23rd February 2012 01:42 PM
Ovation Line Pre-Amp Bonsai Analog Line Level 0 23rd July 2011 05:44 AM
Ovation Amp Bonsai Solid State 14 5th December 2006 12:27 AM
Copyright ©1999-2017 diyAudio
