Old 11th December 2012, 12:35 PM   #81
don't use bitmap. They are enormous file without compression.
You originally used jpeg.
Go into your software and adjust the jpeg compression to give good clarity.
I use Irfanview, there are many others.
Old 11th December 2012, 02:52 PM   #82
Vostro is offline Vostro  Madagascar
Vostro's Avatar
I've explained the best I can.\
but to much off topic
Old 11th December 2012, 04:56 PM   #83
where's the answer to my restating the same question?
Old 11th December 2012, 05:58 PM   #84
jaycee is offline jaycee  United Kingdom
the clarity had nothing to do with jpeg quality though.. it was simply at too low a resolution. If it had not been single colour the software may have dithered it.
PNG is good if you can use it, a 256-colour grayscale image compresses well with that.
Personally im happy to scroll a large, clear schematic
Old 12th December 2012, 06:46 AM   #85
Why are R41 & R42 different value?
1600wide and 170kB
compare to post76 @ 213kB
Old 13th December 2012, 05:03 PM   #86
Vostro, what improvement did you notice by replacing Q21 fron 2N5551 to MPSA42 ??
Old 13th December 2012, 05:11 PM   #87
Vostro's Avatar
The MPSA42 has nicer stats,
But in honesty either works well.
This circuit is a evolution and changes constantly, used for me to learn more.
I don't have instruments to measure THD/distortion,
So to answer your question, the choice to replace the 2n5551 was purely based on datasheets.
I can't notice any difference, on scope and on listening, they the same to me.
What I have not done yet, is check by how much i can lower CDOM,
But I think this will be the last time I use Miller compensation.
Keeping Q23/24 MJE340/350 is also the same
Old 20th December 2012, 11:41 AM   #88
Vostro's Avatar
They don't need to be different values, they were originally the same value then I increased R42 for already mentioned reason, but there was no 'need' to increase R41, and I was happy with stability at current value, so I didnt change R41 to same value as R42,
This is not symmetric VAS circuit so I don't mind them not being same value.
I've not had any chance to work on the amplifier, and sadly wont till January.
@AndrewT, sorry for not answering sooner, for some reason I didn't see the question on the resistors, guess I was just focusing on trying to export jpg in a better way.
Building an amp from scratch - what features would i want speakerfritz Tubes / Valves 35 26th January 2011 03:43 PM
Copyright ©1999-2013 diyAudio
