Big difference in amps - tag/rotel has me confused
Old 1st June 2012, 10:50 AM   #11
j baldam is offline j baldam  United Kingdom
Originally Posted by inteificio View Post
Didn't realize this would be such a contentious issue!
hi, not contentious, but I thought people who may not know should be aware that every single piece of the hi fi jigsaw sounds different and should be auditioned, if possible, and the final combination in an ideal world should be listened to at home, because true hi fi reproduction doesn't exist, just a sound that we are happy with.
When we have found that sound, then we can enjoy the music.
Old 1st June 2012, 11:44 AM   #12
sgrossklass is offline sgrossklass  Germany
Unfortunately the "all components sound different" philosophy had led to all kinds of ridiculous audiophoolery over the last couple of decades.
It is quite possible to build some classes of equipment (like digital sources or amplifiers) in such a way that they cannot be told apart in a valid (precisely level-matched, double-blind, no-clipping) comparison. And honestly, I'd much rather know that my electronics are up to snuff since then I can concentrate on the real elephant in the room (acoustics).
I tried Rotel with both balanced and unbalanced and could not notice any difference.
Expectedly, as balanced outputs tend to be 6 dB louder and the balanced input has a gain of -6 dB (measured total gain was 25.8 dB).
Then compared left right channels on both amps, identical.
OK, but what about one channel TAG and the other Rotel (preferably with mono material unless you have a switch)?
Assuming you have some sines handy, a scope should show a level difference quite nicely, too.
Old 1st June 2012, 11:55 AM   #13
If that were true I could buy a Chinese Black Gate with the confidence that it would sound the same as a genuine Blackgate capacitor.
Panasonic FC sound great in power supplies cheaper ones don't.
The list of known good sounding parts, caps, resistors, transistors etc is endless and if you are telling me that it is some snake oil, then I have to disagree.
To the original poster, yes your amps sound different, because they are
Old 1st June 2012, 12:04 PM   #14
if you do buy and test a 220uF 35V black gate and compare it to a Chinese version of a 220uF 35V (fake), you may/will find they have quite different specifications.
That does not prove one way or the other that the caps have a sound, or have a difference in sound, or affect the way the circuit performs in processing the sound signal.
regards Andrew T.
Old 1st June 2012, 12:49 PM   #15
There is no doubt that parts quality has an influence here and there. But if it's audible, it's easily measurable as well. If, however, I have a piece of equipment for which a sensible and sufficiently comprehensive set of measurements indicates that it should be audibly transparent, I could not care less whether it uses bottom of the pile cheapo Chinese parts or magic pixie dust.
Well, actually I would care - it's always handy if stuff still performs well 20 years after building.
I would not trust part choices by ear much if expected differences are small and listening is all sighted. Obviously transistor choices may be readily audible in a simple amplifier circuit with low loop gain, no doubt about that. (And they would jump at you in measurements.) But swapping out electrolytics in something that powers a bunch of opamps or other components with good PSRR? That's going to be tough.
Old 1st June 2012, 12:53 PM   #16
inteificio is offline inteificio  United Kingdom
[QUOTE=sgrossklass;3044580]
lol, that does make sense.
did that one too, very noticeable. A lot of DB tests on my hifi I would be able to spot there was a difference, but not say what was what. This would be easy. Any song, a few seconds and I would be able to tell you which amp was which.
If we are talking about components I always use black gates too. Not sure how they affect the sound, the reason I use them is they last for ever without issues. I recently serviced the Rotel amp, the only thing that needed fixing was the only cheap cap in the case, the one on the power on circuit!
Quality lasts.
One other thought is the Straight Line tech in the Tags, not seen that before and not a large enough understanding to see how it would work.
The Rotel is biwired off the same terminals, the Tags separate.
Could the back EMF off the drivers make a significant difference if the tags filtered it out?
Old 1st June 2012, 01:06 PM   #17
Nico Ras is offline Nico Ras  South Africa
Nico Ras's Avatar
The sound change is significant, even my wife could notice the difference (and that is saying something).
P
Another proof that married woman have no clue about sound.
Kindest regards
Nico
Old 1st June 2012, 01:18 PM   #18
The important thing is they do not discover how much good sound costs.
If she asks I spend no more than 50!
Old 1st June 2012, 02:17 PM   #19
sharpi31 is offline sharpi31  United Kingdom
I used to sell both Tag & Rotel kit. Splitting a given budget over a better Tag processor and Rotel power amplification always gave better sound than buying an all Tag system (with lesser processor and more spent on amps). There was less of a difference in quality between the amps than the different Tag processors.
Old 1st June 2012, 02:55 PM   #20
Did you get to compare the Tag 125m and the Rb-991? Way different pricing (2400, vs 650), but wonder how quality compares?
I prefer the TAG, wifey the Rotel.
Big difference in amps - tag/rotel has me confusedHide this!Advertise here!
WANTED : Rotel Preamp (with Remote) & Rotel Power Amps - Working or NOT dtm1962 Swap Meet 7 18th December 2012 07:45 PM
New to Valve Amps and Confused??? paulluvsmusic Tubes / Valves 6 27th September 2009 08:46 AM
Is the big difference of L15RLY compare to W15CY ? fdw412 Multi-Way 1 12th April 2009 11:31 AM
Big sale thread: PHL, Raven, Amps, In-wall/ceiling speakers, Amps, VideoRequest mbcouple Swap Meet 2 27th October 2008 11:27 PM
Copyright ©1999-2017 diyAudio
