#21 | |||
#22 |
Dear WAHAB, can instead be placed R603-R604 50K multiturn trimpot and then adjust it so that the DC offset is as little as possible?. I appreciate your opinion. José.
Varying the resistor, the dc offset varies?. |
#23 |
Let's not confuse AC noise with DC offset. If you are hearing noise from your amp, that is a totally different set of problems.
Yes, Rotel, and many other brands have intentional errors in the schematics. An experienced tech will have no problem. I am guessing this is some kind of trick to watch for copyright or rip-offs. Seems silly to me. Trimpots, just like the rest of the circuit, are not stable with temp. A bit of old age, and they can do really bad things, like open. Then you are talking full rail offset. Duck while the woofers come flying at you. No, either do a proper servo, or leave well enough alone. You have been warned. Part of DIY is to do as you wish anyway and suffer the consequences. You can get luck or you can end up with blown amps and speakers. Your choice. Pay to play. Myself, I am so old that I don't have time to learn everything for myself every time, so I listen tho those who have been down that road before. Want to know how much a set of Exicon MOSFETs for a Hafler cost? That's a hint son. |
#24 | |
but you cant use different final values for each channel as the passive tone control output wich has about 1.5K output impedance is connected directly to the power amp input. This mandate the same value for the two channels otherwise the tonal and volume balance will be set out of symetry when the tone control is used. Since you ve got 68mV and 45mV DC offset for each channel respectively , that is 23mV dc inbalance , reducing to 12K will surely be optimal only for the former while the latter would need perhaps 22K , the optimum will surely be to set the said resistor such that one channel is about -11.5mV and the other one at +11.5mV. Edit: After checking with pots use the nearby resistors values since potentiometers are not reliable as pointed above. As a side note , this kind of symetrical differential topology, wich i prefer, is very rare and doesnt even account for 0.01% of the amps sold to this date.... Last edited by wahab; 30th May 2012 at 09:58 PM. |
#25 | |
Very rare ??? Every Rotel since around 1990 uses this simple schematic, more output devices for higher output is about the only differences to high power models together with vas cascoding, although it is a patented form of cascoding that rotel uses.
#26 | |
so I really doubt noise level is such a problem. The design is by Stan Curtis.
#27 |
Ah, now I know whom I may complement. Thank you Mr. Curtis.
#28 | |
![]() The usual single LTP + VAS + OPS is surely 99.99% of all the produced amps since the early 70s , and 100% of the eventual chip/thick film amps.... |
#29 |
The typical Rotel power amp is a pair of complementary LTPs (no emitter degeneration, crude current source and single ended loads) followed by complementary push pull VAS and output triples with no protectio0n circuits. Oddly there is no rail RC filter to the sensitive bits. The circuit depends on npn-pnp symmetry for offset and to reject rail ripple.
#30 | |
I alone have 7 of various models, whenever I can buy one second hand for cheap I plunge and with a little tweaking these amps sound great. |
| DC offset | GregH2 | Solid State | 35 | 30th March 2012 03:04 AM |
| DH-220 Clone (SMART TA-242) can't adjust DC offset using offset bias pot? | beady | Solid State | 6 | 17th March 2011 10:53 AM |
| Rotel RCD-971: Anyone revised the PCM63 Current Output Config-Source of DC Offset??? | dtm1962 | Digital Source | 3 | 25th November 2010 08:39 PM |
| Help with a Rotel RSX965, 2V neg offset, all outputs | Bill Fuss | Solid State | 3 | 25th September 2010 10:13 PM |
| DC offset need help again :-( | djdamix | Solid State | 13 | 26th October 2004 08:38 AM |
