amplifier biasing help - diyAudio
Old 27th May 2012, 02:39 PM   #1
Default amplifier biasing help
hi
i have replaced TIP35/36C blow out put stage trasistors from Focal amp and replaced with 2SC5200 pairs.
Now there is a REFERENCE POINT and BIAS CHECK point. The voltage across all four channels is 2mV to 80 mv.
VCE= 30.6 volt for all
VBE= 0.35V to 0.55 Volt ?
Any guidance how to adjust bias before i blow them out again.
Old 27th May 2012, 03:20 PM   #2
The question is back to front with the action.
You ask before you power it up !!!
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 27th May 2012, 03:24 PM   #3
No. Actually its second replacement, the yesterday replacement were all well before i put a bridged load on it.
so yes i am asking before powering it up before second time. But i am using series bulbs with the power supply just in case.:-)
Old 27th May 2012, 03:37 PM   #4
Originally Posted by muddasirwaheedmalik View Post
hi
TIP 35 is an NPN whereas TIP36 is PNP inferring a complementary pair. 2SC5200 is NPN, It would suggest to me that you need a PNP to match the replacement of the TIP36.The correct complement for the 2SC5200 is a 2SA1943
Cheers / Chris
Old 27th May 2012, 03:48 PM   #5
just forgot to mention though in my earlier post. yes indeed it 2SA5200 was matched with 2SA1943, and tried to match within 5% of VBe, not sure of hFE though.
Biasing ? VBE ? HELP?
Old 27th May 2012, 04:06 PM   #6
Data sheet here: http://www.fairchildsemi.com/ds/FJ/FJL4315.pdf
Cheers / Chris
Old 27th May 2012, 04:09 PM   #7
DF96 is offline DF96  England
Have you tried circuit fault-finding to discover why they blew?
Old 27th May 2012, 06:37 PM   #8
accidental short circuit at output while trying to put an OP transformer. :-(
Old 27th May 2012, 09:44 PM   #9
OK, so there is not a fault to trace unless the output transistors took something else with them when they died.
Old 27th May 2012, 10:22 PM   #10
nigelwright7557's Avatar
A bridged load needs to be twice the none bridged load.
Murton-Pike Systems PCBCAD51 pcb design software. http://www.murtonpikesystems.co.uk http://www.pcbcad51.co.uk
Biasing MOSFET amplifier HighTower Solid State 23 9th May 2012 11:09 AM
Biasing this symmetrical Class B Amplifier Boscoe Solid State 4 14th March 2012 06:06 PM
low-biasing or high biasing in Class-AB amps Workhorse Solid State 124 18th October 2005 05:45 AM
Medium-fi amplifier biasing Circlotron Solid State 1 24th July 2002 03:44 AM
Copyright 1999-2017 diyAudio
