In this project
you can see an inverting power amplifier with: a) only 4 stages b) common base VAS and c) low gain output devices input impedance is low so need a Op-Amp preamplifier ideal gain is G=10
#2 |
the 24s and 25s are reversed.
You're not running much current through the input transistors. How do you expect to develop any voltage across the 150Ω resistors?
Candidates for the Darwin Award should not read this author. Last edited by djk; 29th May 2012 at 12:33 PM. |
#3 |
see now if works
| FS- Twisted Pear Buffalo 32S Board & System New & Unused | secretriches | Swap Meet | 1 | 10th August 2009 02:17 PM |
| Modify & build out (2) Western Electric 300B / 2A3 Hammond monoblock amps & UTC LS-5 | quality sound | Tubes / Valves | 0 | 9th May 2009 03:59 PM |
| Krell KSA 80 bias & dc offset check & adjust procedure | Clouseaupte | Solid State | 3 | 9th August 2007 09:39 AM |
| DIY-AMP <ZAS> Low THD & IM high bandwith | murphy | Solid State | 18 | 30th December 2005 10:28 AM |
