Cambridge Audio A1 MK3 SE repair (TDA1514 chips burned) - Page 2 - diyAudio
Old 29th May 2012, 11:22 AM   #11
I was thinkin that I would measure look if the fuses wont burn with new capacitors and no TDA1514A:s in place. If all would be well and I could measure the voltage at the points where the TDA1514A:s are placed I'd solder them in place.
The bim bulbe tester seems interesting enough for future projects too, but I have no spare parts for it now.
Old 29th May 2012, 11:59 AM   #12
AndrewT is online now AndrewT  Scotland
The bim bulbe (Dim Bulb) is needed now.
Don't power up any modified or new project without it !!!!!!!!!
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 29th May 2012, 12:11 PM   #13
check for possible short circuit of output.
allso, use a fast blow fuse, half of the original rating.
prior installing a new chip do mesure the voltage on the board, and see if everything is normal.
use a 10K resistor as load, and mesure output voltage.
I find it hard to burn a TDA chip. actualy i use them verry often to power all short of things.
Old 29th May 2012, 03:49 PM   #14
Thanks for the tips! I replaced the caps and tried powering on. The fuse still blows on the left side. Started withouth chips, so no damage done. I measured the big power caps, the right one shows 25v as the left one is at zero.
Measured the output terminals for shorts but found nothing.
Old 29th May 2012, 05:06 PM   #15
Check the transformer secondaries for continuity and the bridge. Working with one rail shorted is not going to do the chips any good.
I always have a look at the output network resistors, 3R3 if they followed the data sheet. Typically these are under-rated and fail open. This makes the chip oscillate and fry.
Old 29th May 2012, 05:12 PM   #16
With no chips in, you still have a short. The main supply is also regulated down to +/-15V to supply opamps. You will see a pair of 7815/7915 on there - check those.
You may also find that the board itself is damaged. Are there any burns on the PCB ? Burnt PCB can become conductive.
Old 29th May 2012, 06:50 PM   #17
Thanks guys! I might have found the culprit, a transistor marked U3 is split in half:
http://dl.dropbox.com/u/2631716/ca_a1mk3_transistor.jpg
Might take it out and see if the fuse still goest. Need to order a spare for this anyways so there will be a wait.
Shot of the power amp board, all boards seem intact so no burns.
http://dl.dropbox.com/u/2631716/ca_a1mk3_pab.jpg
Old 29th May 2012, 07:23 PM   #18
Transistor U6 at the other opamp also has a busted leg, also needs replacement. Different types of transistors, both hard to get here in Finland.
NTE1905 and NTE951 would be working replacements it seems.
Old 29th May 2012, 08:28 PM   #19
Allright, I think Im done tinkering for today. I took out U3 and U6 transistors, plugged out the preamp board and fired up the power amp board.
This resulted in C29 and C31 caps exploding (or putting out smoke). A good sign maybe? Atleats the voltage is going on both rails, it didn't like being fired up without the TDA1514 in place and no preamp board plugged?
Old 30th May 2012, 12:30 AM   #20
They aren't transistors - they are 78L15 and 79L15 15V 100mA regulator IC's, in TO92 package, used to power the opamps.
http://www.onsemi.com/PowerSolutions...do?id=MC78L15A
http://www.onsemi.com/PowerSolutions....do?id=MC79L15
ELFA Finland have them, and I expect other suppliers will too. They don't have to be the Motorola versions, and they are quite commonly second sourced by many manufacturers.
Cambridge Audio A1 Schematic Billicar Solid State 23 25th October 2014 08:53 PM
Cambridge Audio A1 mk3 upgrade mods Honda Z50M Chip Amps 28 1st March 2014 03:08 PM
A broken cambridge audio A1 MK3 katanassn Solid State 11 23rd January 2006 11:52 AM
Cambridge a1 MK3 TDA1514a chip katanassn Chip Amps 5 15th November 2005 10:06 PM
Cambridge Audio A4 Burned resistors ChrisW Solid State 0 2nd May 2005 05:55 AM
Copyright 1999-2017 diyAudio
