#21 | |
ADD: I just simulated F5. Like I thought previously, the HF THD is awful... My TSSA is much better. Last edited by Jay; 25th May 2012 at 02:13 PM. |
#22 | |
I've mentioned IMD in the past...
and distortion cancellation is real - diff pair, complementary or push-pull output stages can cancel even order terms that match between the devices Dr Cherry has claimed increasing bias to signal ratio, cancellation and negative feedback are pretty much all we have after selecting amplifying devices - and negative feedback is the only technique that can practically be used for factors of >1000x of distortion reduction Last edited by jcx; 25th May 2012 at 02:50 PM. |
#23 |
#24 | |
or even following a cubic law if no linearization is applied at OL , using degeneration , although the design "choice" will only change the starting point , that is THD at low frequency , but will left HF THD ratio unchanged. |
#25 | |
Distortion cancellation is where one stage has a non-linearity that unbends the non-linearity of another stage in such a way as to produce a more linear result. Another method of distortion cancellation is the careful selection of a device's operating point such that two distortion mechanisms cancel. See the third link. http://www.firstwatt.com/pdf/art_dist_fdbk.pdf http://www.firstwatt.com/pdf/art_sweet_spot.pdf http://www.firstwatt.com/pdf/art_zv9.pdf (see page 4) |
| 'Perceive' Contruction Diary | ShinOBIWAN | Multi-Way | 440 | 8th September 2010 09:14 AM |
| OT: how can I measure THD of my amplifier if my sound card is 0,02% THD ? | ygg-it | Solid State | 1 | 13th June 2010 07:54 AM |
| Any comments on Eico HF-14 and HF-85 | percy | Tubes / Valves | 5 | 13th January 2005 12:11 AM |
