Self regulating Class A
Old 18th October 2003, 03:04 PM   #41
Mark A. Gulbrandsen is offline Mark A. Gulbrandsen
Circlotron's idea would work beautifully for pre-caluulating the bias needs and I'm surprised that Krell hasn't marketed that sort of thing as of yet..... That would make all the difference in the world.
Its very similar to how record cutting lathes use the preview head on the playback deck to vary the groove pitch needed based on level and frequency.
Mark
Old 18th October 2003, 03:30 PM   #42
Christer is offline Christer  Sweden
It is a quite obvious idea, I think. I have had that idea too, and
I am sure many many other have as well. There are some obvious
problems with it though. First, it works only for digital sources.
Second, it cannot be implemented in the power amp, unless it
has digital in and contains the DAC, but must be implemented
already before the DAC(s). That is, it must be implemented both in
CDP and other sources and these must also provide an extra
output for the "presignal". It is not impossible to do. To the
contrary it is quite simple, but it is likely to be highly unpractical
unless there is some standard for it or all of the equipment are
designed to work together as a whole. A remaining possibility
would be an analog delay line, but that would probably be much
harder to implement with sufficient delay and without affacting
the sound negatively.
Come to think of it, it could be implemented for turntables by
using two tonearms, which I think would be something similar
to what you said about record cutting. Well, we might also
consider tape recorders with a tape loop, but most would
probably consider that good enough regarding sound quality.
Old 18th October 2003, 04:37 PM   #43
jewilson is offline jewilson  United States
Send a message via AIM to jewilson
Default Sliding Bias
This could be done with a sample and hold circuit. This also could be done with a DAC and a look up-table; of course, that means a small processor and some logic. In addition, this could implemented with a comparators, threshold detector and a RC time constant.
Jim W.
Old 18th October 2003, 06:00 PM   #44
A manufacturer like Krell that also produces their own CD players/DAC's could easily pull this sort of thing off. The CD player would simply have two analog and two digital outputs...one set of outputs would be delayed a tad bit from the other to operate a bias control input on the amp. The attack time of the bias control circuit would be fast but the release time would be much slower to take into account the DAC and preamp being used on the second delayed output. the amp wopuld also have the standard sounds bad dynamic biasing sceme available to work with other brands of equipment.
Mark
Old 18th October 2003, 06:07 PM   #45
Sure they could. As I said, it is not particularly difficult to
implement if you control the whole chain. The question is, though,
how many customers have all Krell equipment, or all brand
whatever. It also precludes analog sources like turntables, unless
they are equipped with alternative methods to achieve the same
effect. Of course, the power amp could sense whether it does
get two versions of the signal and use sliding bias only when
it does get both a "presignal" and a signal, but then the benefit
is lost when listening to the "wrong" source.
Old 18th October 2003, 06:11 PM   #46
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
Originally posted by GRollins
It still seems that you're going to be faced with a lag problem. Take something like the Gladiator sound track that starts off on the soft side of normal and just keeps getting louder and louder and louder. Unless you purposefully build in a little overshoot on the assumption that louder is to come, you're still going to be playing follow-the-leader when the music exceeds your previous set point.
You are assuming that I was referring to a music-variable circuit,
which I was not. I was referring to a circuit which holds a
constant bias A or AB, and slowly adjusts the bias voltage to
keep that figure.
If you want variable bias, the original dynamic bias concept (mine)
is probably still the best because it tracks instantly - it's really
part of the gain stage, and as I have said before, Cordell and
Hawksford have used to reduce distortion numbers in the
output stage of AB circuits. From the schematics, I would say
it's the central mechanism providing the distortion numbers
for the Halcro.
Old 19th October 2003, 02:47 PM   #47
GRollins is offline GRollins  United States
OK...lemme think on that one. A couple of ideas come to mind, but I'll need to ponder on 'em for a bit and see if they're practical.
Grey
Old 19th October 2003, 03:16 PM   #48
"If you want variable bias, the original dynamic bias concept (mine)
is probably still the best because it tracks instantly "
__________________________________________________ __
Nelson,
Doesn't thermal stabilization and overall temperature have a big effect on overall sound quality in alot of amps including your designs? The Alephs don't really sound their optimum till they reach normal operating temperature which takes about an hour. While your circuit may act instantly on the bias level or mode, the thermal end of things will still take a while to achieve so there is that lag......
Mark
Old 19th October 2003, 04:54 PM   #49
The one and only
These are two separate issues. The characteristics of the
output devices are dependent on temperature, and typically
an amp should be allowed to warm up before being adjusted
for optimal use. In my amps, we reach higher transconductance
in the Mosfets at the higher temperatures, so there will be less
distortion. This is also where we do any adjustment.
Of course warming up usually also means a shift in bias, and
here we have been talking (I think) about means of automatically
adjusting bias, which implies temperature independence.
Old 21st October 2003, 01:57 AM   #50
jcarr is offline jcarr  United States
Don't recall if US patent 4,229,706 by James Bongiorno has been mentioned, so here's the link:
http://patft.uspto.gov/netacgi/nph-P...number=4229706
regards, jonathan carr
http://www.lyraconnoisseur.com/, http://www.lyraaudio.com
Self regulating Class AHide this!Advertise here!
DC fan speed regulating question sunrise Solid State 23 7th August 2006 04:31 PM
regulating voltage for preamp alizawi Chip Amps 56 12th May 2006 12:47 PM
LM3x7 HV regulating. w00t Parts 3 29th February 2004 09:42 PM
7815 not regulating. JoeBob Solid State 16 8th September 2003 12:51 PM
