N-mos Power Amp , my project need some help , Thanks . - Page 2 - diyAudio
Old 26th May 2012, 03:08 PM   #11
Banned
With those kinda powers in mind, i suggest you buy a PA amplifier from somewhere like behringer, labgruppen, qsc, crown, etc.
Old 30th May 2012, 02:42 PM   #12
thienchay's Avatar
hi hi , thanks you so much for good idea . But i wanna try , i wanna DIY , because i love DIY , so so much
I 've was DIY some project , Naim clone , Leach All in One , some MOSFET , some Transistor ... and more , and i wanna try this project , Nmos power amp , because i'm not yet know it .
And now , first i 'll try this schematic , to get more experience with Nmos Power , i 've was Layout this circuit , and i 'll test it soon .
(sorry for my English)
Thanks Tekko so much
Thanks All
___________
regards
Old 30th May 2012, 02:47 PM   #13
thienchay's Avatar
with that PCB , the T8 will connect to the main heatsink with 3 wires .
Old 31st May 2012, 02:50 AM   #14
masood is offline masood  India
Originally Posted by thienchay View Post
thanks dungdochi1987 and Ian Finch
i'm have a Quasi 's design power amp , about 600W .
Please help me , this circuit is reliable and safe ? , if i used 12 x IRFP450 , and +/- 90VDC , i would have how much Watt Output ?
And help me a protect circuit in output stage , first is protect power amp , and if my amp damaged , protect the speaker .
Thanks so much .
thienchay
____________
regards
dear sir,
would you share its pcb?
thanks masood
my e mail is khan.shahid251@gmail.com
Old 31st May 2012, 03:06 AM   #15
CBS240 is offline CBS240  United States
CBS240's Avatar
VR2 has the wiper connected to the base. Unlike in a simulation, what would happen if the wiper point contact became dirty or loose, turning off completely T8? (hint=> )
Vbe multiplier bias should be re-configured. Also the temperature co-efficient of a B-E junction is not nearly the same as the temp-co of G-S in the mosfets. A Vgs multiplier with a mosfet as thermal compensation would be more appropriate.
All the trouble I've ever been in started out as fun......
Old 31st May 2012, 11:03 AM   #16
thienchay's Avatar
Originally Posted by masood View Post
dear sir,
thanks masood
yeah , thanks for interest .
I'm do it by Sprint - Layout 5.0 , so i just have file " .mdi"
I don't know how to export to PDF file .
Old 31st May 2012, 11:09 AM   #17
thienchay's Avatar
Thanks you so much .
So can you help me modify it to safety more .
Thanks you
Old 31st May 2012, 12:07 PM   #18
thienchay's Avatar
Hello .
I 've modified it into like this , please see help me it OK or Bad ? can i do like this ? . I need the safety for my Amp
Old 31st May 2012, 06:05 PM   #19
dear!
almost of amp is working in oder because they've already build it up.
you should read all details of amp which is explained ( search The Leach amp 200W amplifier, read all amps in audio denmark ) .and then you can MOD by yourself.
you want high power, no need more voltage ~90V dangergous -shock but you can try with BTL circuit .it will enought for you .Neighbour will complain to you ( I've already hear with my neighbour-seem no good,..then. i sold it ).
all circuit protection will working before speaker burn and if you want more safety better never turn it on.
MOS Power Amp -My Design Bob Scott Solid State 5 5th April 2010 04:05 PM
Sheldon Stokes MOS FET amp as power amp wleediy Solid State 0 29th January 2008 02:59 PM
Need to know about a MOS. FET output stage ( the Baby 300B) power amp plans gaetan8888 Solid State 1 18th April 2007 05:35 PM
power mos for Aleph 30 same Pass Labs 5 24th January 2007 03:42 AM
n-mos half-bridge class D amp, how to drive high side n-mos? zilog Class D 1 30th October 2005 09:46 PM
Copyright 1999-2017 diyAudio
