quad 33 comments please
my quad 33 pre has arrived.
After a bit of fiddling I managed to get it working on both chanels, radio2 only seems to work on 1. Radio 1 is fine.
Could any 33 owners please comment about the innards of this particular amp as I was going to mod it but it seems someone may have got there first.
Peeking inside I notice that all control pots are green plastic, all the pics I've seen show larger metal pots.
The volume pot does not have the facility to switch on and off, the amp is on all the time.
I've pictured the two main boards and they seem different to standard as does the power supply board. And the power supply wiring.:)
http://i1095.photobucket.com/albums/i464/Jbaldam/DSCF1911.jpg
http://i1095.photobucket.com/albums/i464/Jbaldam/DSCF1914.jpg
There is a liberal application of some silicone like substance over most components and boards
It looks like:
1) All the pots have been replaced.
2) Most of the electrolytics have been replaced.
3) Some of the film capacitors on the M12017 pcbs are original, some replaced. The green box capacitors can certainly be original.
4) The mains input wiring looks non-original, and there is also some new wiring from the power supply board to the main pcb.
I am mystified as to why anyone would want to put that sealer/glue on the boards.
The Quad 33 is pretty straightforward to work on and you should have no trouble dealing with any problems. Report back if you're stuck on anything.
hi, lost in translation, it's 2.2 uf.
I sent the pics to DaDa europe and he reckons that although a lot has been replaced I would be better off following their kit values.
I will be using cd into the tape board so there won't be a lot to do.
Power supply increase and changes to the tape board.
hi, I have had some interesting advice from DaDa Australia.
He pointed me towards a mod on the power supply.
Basicly you remove all parts from the power board except the transformer.
Two diodes are added for rectification.
A 12v reg is fitted and a 2200uf cap and 100uf cap and a link across c504.
I have done this and the results with CD into the tape board are outstanding.
This has impessed me so much that I have called it a day with modding.
I am now rediscovering my old CD's.
Link here
Quad Spot
As sbrads menetioned, glueing stuff to the PCB is what is done in military/aviation (at least they used to do it, don't know if it is still done). Some PCBs were even casted into epoxy, a one way only solution. It makes sense for electronics in a high vibration environment, but I don't think it has benefits for a pre-amp.
Glueing is still done in military gear, but usually it's only big wobbly components that get bonded down, all the small stuff just gets conformally coated (like a varnish that you can solder through for repair work). If there's a heatplane (a flat metal plate with holes for component leads bonded to the topside of the pcb), then ICs and 'laying down' components may get a heat transfer compound under them, usually a liquid that sets, for cooler running.
