Home Forums Articles Gallery Blogs Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
Thread Tools
Old 24th April 2003, 02:38 PM   #41
Circlotron's Avatar
Originally posted by x-pro
Hi all, for 10 years I was making amplifiers with N-channel only MOSFETs in the output and really like these devices.
Hi x-pro. I like them very much too. would you like to post some info on your knowledge of them, particularly the gate drive / phase spltting circuitry needed to drive the lower mosfet. I think this kind of cct is becoming a dying art.
Right - back to the thread.
Best-ever T/S parameter spreadsheet.
http://www.diyaudio.com/forums/attachment.php?s=&postid=353269&stamp=1079781945
Old 24th April 2003, 02:45 PM   #42
x-pro is offline x-pro
x-pro's Avatar
Check the link in my post in the "Quasi-complementary Hexfet monstrosity" thread
Al
Old 24th April 2003, 02:51 PM   #43
Circlotron's Avatar
The main advantage of the MOSFET ouput stage, in my view, is that it has low output impedance even without NFB, and does not change the load of the voltage amplifier as much as BJT output does with the load change. Al
Could this be a property peculiar to logic level fets? My experience with normal n-channel type switching hexfets in linear mode is that they have a fairly "soft" and squishy output impedance with voltage changing under load from zero to full maybe 5 to 10% depending on output level. This improves greatly though when you crank up the bias to something like Class A levels because the transconductance increases with current so the output impedance drops a fair bit.
Old 24th April 2003, 03:05 PM   #44
x-pro's Avatar
In my circuit I did measure less than 0.5 Om output impedance with about 100 mA idle. Logic level devices certanly have higher transconductance - it helps. However they also much easier destroyed by an overvoltage on the gate. Thankfully, in my design it never goes over 2xVth.
Al
Old 10th September 2003, 09:09 PM   #45
gwolf is offline gwolf
gwolf's Avatar
Al,
I never found a Spice model for the BUK (555, ...) devices. Do you have them?
Gerhard
Old 10th September 2003, 11:18 PM   #46
x-pro's Avatar
BUK555 are obsolete anyway. Try BUK9540-100A as a replacement
x-pro
Old 11th September 2003, 06:56 PM   #47
gwolf's Avatar
x-pro
Yes, I know. But I still have a bunch of BUK555-100B in my drawer. But even from the BUK9540 I could find no usable spice model. Any idea?
Gerhard
Thread Tools
Taking the B&W 683 Active amo Multi-Way 3 28th June 2008 10:55 AM
Taking Paint Off Wood kvk Everything Else 7 25th March 2008 12:16 AM
Taking CFB to the extremes...? Fuling Tubes / Valves 17 15th September 2006 09:50 PM
I'm taking the plunge! zagisrule! Solid State 3 2nd May 2004 10:29 PM
Page generated in 0.07911205 seconds (77.35% PHP - 22.65% MySQL) with 10 queries
Copyright ©1999-2010 diyAudio
