Carver PM1.5 problem
Then move to the ground between R17 and R51 - is it good?
Check Q16, Q17, Q18, and Q19 - are they good?
With a dimbulb, are the power supplies on either side of R15 and R52 equally above and below ground potential?
Are R15, R16, R50, and R52 all in spec?
Is RP-1 reading a suitable value across pins 1 and 3?
Is C5 open or shorted? Does your meter measure capacitance? (Most good meters go up to 20uF)
If you can't measure it, does it charge in both directions on the highest ohm setting?
Plan D: replace C5 anyway.
Did you test Q15 across all 3 pins, both directions?
