New home brew amp module
Old 15th September 2017, 12:18 AM   #61
CBS240 is offline CBS240  United States
CBS240's Avatar
Yes, it does appear to be lower than pure copper.
Good link, nice chart! That may helpful: ) I'm not sure about % of copper, it was part of a finished and polished sign of stand out symbols made of a gilding brass I assume😕, probably high copper but really it is the realitive mass of the material that aids in keeping a safer limit on peak temperature rise, at the expense of higher average temperature, of which does not affect these devices. I think being able to use a larger surface area for the mica insulators is a big advantage. If I could get pure copper shims, coated or gold plated, that would be awesome. As it is, scrap metal IS cheaper. . In all, so far, I have not had a problem with overheated transistors as long as they are tightly mounted. Driving it till it blows is one of the tests I intend to perform.😎
All the trouble I've ever been in started out as fun......
New home brew amp moduleHide this!Advertise here!
problems with preamp on home brew jeeptechfred Tubes / Valves 2 17th May 2011 01:13 AM
Home brew polyphase amp guzzibreva1 Class D 8 25th April 2011 07:09 PM
Home Brew Ampeg B25B JJWright Construction Tips 2 13th April 2011 07:50 PM
The PINNACLE of Home Brew Amps - Or Not... camshaft Solid State 14 26th March 2008 12:13 PM
home brew PCB production GeeVee Parts 10 5th May 2007 03:36 PM
Copyright ©1999-2017 diyAudio
