Old 8th October 2003, 06:39 PM   #1
5th element's Avatar
Default Active notch filter
http://www.linkwitzlab.com/filters.htm#7
This shows a notch filter.
Does anyone know the design formula for design B?
Am I being an idiot and not recognising that its actually there?
Cheers for any help Matt
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Droggon Attack!
Old 8th October 2003, 07:56 PM   #2
moamps is offline moamps  Croatia
http://www.linkwitzlab.com/images/graphics/inductr2.gif
Old 8th October 2003, 08:56 PM   #3
Yes that tells you how to calculate the value of the inductor.
But what about the frequency it all works at?
The Q of the notch? and
The size of the notch (db)?
I knew about that bit but not the rest.
Old 8th October 2003, 09:53 PM   #4
jackinnj's Avatar
You should probably step back for a minute and take a look at some of the tutorials on filter design.
TI has a good tutorial on their website.
Old 9th October 2003, 10:05 AM   #5
Look I have used active filters in the past to great effect and am in the process of building another. I know how to use them. This project tho calls for a notch filter which I have never had to use before. So hence I dont know how to calculate one. All I need to know is the formulas. If TI has this which I will look into then great. I was just wondering wheather anyone knew the formula LW has used in that notch.
Old 9th October 2003, 12:20 PM   #6
jackinnj's Avatar
I don't think that Linkwitz changed any of the principles of electrical engineering.
Q = w0 RC
Old 9th October 2003, 12:26 PM   #7
Gyrator (simulate inductor)
http://www.national.com/an/AN/AN-435.pdf
Old 6th February 2004, 10:06 PM   #8
JensRasmussen's Avatar
Send a message via ICQ to JensRasmussen Send a message via MSN to JensRasmussen
Default I think there is an error here ?
The drawing has an error I think.
The parallel resistor across the inductor needs to be R2-R1.
\Jens
need help wana change 60-Hz twin-T notch filter to 279 Hz filter prorms Solid State 0 9th February 2008 11:38 PM
Can Zaphs notch filter be used without the BSC filter? GuyPanico Full Range 0 21st July 2007 01:27 AM
Active Notch Filter design needed Vikash Multi-Way 63 21st May 2007 05:14 PM
Notch filter qguy Multi-Way 3 26th October 2006 09:26 PM
Noise out of active notch filter reins Multi-Way 0 6th July 2006 07:34 PM
Copyright ©1999-2013 diyAudio
