JVC VN700 power off problem - diyAudio
Old 10th May 2012, 12:51 PM   #1
Default JVC VN700 power off problem
Hi All,
I have a JVC VN700 which switches off after 12 mins or so of use. On re powering, it trips againg after a few seconds. Sounds like a component faliure but could do with some advice to save lenghthy check.
If anyone has experienced this problem or has any advice, I would be very grateful.
I have checked the amp without speakers and with one chanel only, same problem so I guess the output trans are ok?
Old 10th May 2012, 01:57 PM   #2
On an amp this old, it is probably the effect of dried out electrolytic capacitors. Measure the DC voltage on the speaker terminals from cold, and you will probably find it is rising slowly to the point where some protect circuit trips.
Old 10th May 2012, 02:16 PM   #3
Service manual here: JVC VN-700 | Owners Manual, Service Manual, Schematics, Free Download | HiFi Engine
Old 10th May 2012, 05:01 PM   #4
Thanks for the advice, very much appreciated as I don't have an electronics background just some basic knowledge through messing around with vintage valve amps.
DC voltage measured over 100mv on one chanel so I took out one of the what I think are the preamp boards (TAD809) to test and found the culprit. The other board measures around 38 in both left and right slots.
With my limited knowledge, I will start by changing the caps and move on to resistors. I will have to do some reading on transistors!
Thanks again for your help
JVC Shelf Component System Power supply julianjym Power Supplies 18 26th July 2011 06:07 PM
JVC turntable speed problem Fonic Analogue Source 1 7th June 2009 11:37 AM
Problem with PPI amps - POP on power on and power off Onkel Alex Car Audio 8 19th October 2008 07:48 PM
JVC Problem johnboy89 Car Audio 2 21st November 2007 01:18 AM
JVC M-3030 power amp schematic? mikeks Solid State 8 2nd September 2006 12:17 AM
Copyright 1999-2017 diyAudio
