Old 10th May 2012, 07:29 AM   #1
Circlotron's Avatar
Default Biasing output transistors with constant base CURRENT
So we all know that you can't bias your output transistors with a constant voltage because as they heat up the Vbe drops and the transistors turn on harder and pull more current. Not stable with temperature changes. What though if we apply a small but constant CURRENT to the bases of the output devices? Changes in Vbe with temperature would then have no effect. Does the current gain vary much with temperature though? Maybe that's not the right word – we are not dealing with changes in collector current vs changes in base current – just a fixed base current vs changes in die temperature. Any opinions?
Best-ever T/S parameter spreadsheet.
http://www.diyaudio.com/forums/multi...tml#post353269
Old 10th May 2012, 08:33 AM   #2
sofaspud's Avatar
BJT's are current-controlled devices, i.e. there is a fixed relationship between Ib and Ic.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine
Old 10th May 2012, 08:48 AM   #3
DF96 is offline DF96  England
BJT collector current very accurately follows the exponential of base-emitter voltage, over many decades of current (but with a temperature-dependent scaling). BJT collector current is very roughly proportional to base current; the ratio varies being generally lower at very high and very low currents.
Old 10th May 2012, 09:24 AM   #4
Bonsai is online now Bonsai  Taiwan
Bonsai's Avatar
I think voltage biasing is the best solution! better to rather spend some efort on improving the temperature stability, or on developing some form of error correction circuit to counteract distortion due to temperature induced bias errors.
bonsai
Amplifier Design and Construction for MUSIC! http://hifisonix.com/
Old 10th May 2012, 09:27 AM   #5
godfrey is offline godfrey  South Africa
Yes. That's normally shown on the datasheet. e.g. See the pic below. Current bias of the output stage is still workable though. For example the 1969 JLH class A amp uses it.
Old 10th May 2012, 09:42 AM   #6
sofaspud's Avatar
Constant base current bias?
Old 10th May 2012, 01:49 PM   #7
Circlotron's Avatar
I was primarily interested in class B application, but thanks for the graphs.
Old 10th May 2012, 02:43 PM   #8
Elvee is offline Elvee  Belgium
Elvee's Avatar
The Circlophone falls more or less into that category.
. .Circlophone your life !!!! . .
♫♪ My little cheap Circlophone© ♫♪
Old 10th May 2012, 11:59 PM   #9
Circlotron's Avatar
So it does! Hey, that's pretty good.
Determing current dump from output transistors Arroyo Solid State 3 10th June 2011 01:19 AM
Why is it not a Constant Current Source ? payloadde Power Supplies 3 17th April 2011 09:59 PM
Would it be nice to have constant current on the output transistors ? Bernhard Solid State 11 12th April 2009 12:31 PM
constant current sources... cathode_leak Tubes / Valves 10 29th March 2005 10:18 PM
Constant current PRBS Pass Labs 6 24th March 2002 12:49 PM
Copyright ©1999-2013 diyAudio
