Old 5th May 2012, 12:48 PM   #1
ba3jar is offline ba3jar  England
Default BALDWIN GERMANIUM AMPLIFIER
Hi
i'm looking for schematic belong to a Baldwin Professional germanium amp , can anyone help ?please
the amp with the link bellow:
BALDWIN GERMANIUM GUITAR AMPLIFIER AMP REVERB TREMOLO TIMBRE WILLY NELSON | eBay
Old 5th May 2012, 02:21 PM   #2
It has been a long time since I looked at a Baldwin amplifier schematic. It used all PNP power transistors and interstage transformers. But sorry don't have a copy.
Old 5th May 2012, 03:41 PM   #3
do you know which PNP model number used in such amp?
Old 5th May 2012, 04:11 PM   #4
As I recall it was a house number, but the standard NTE replacement Germanium PNP power transistor as a pair worked just fine to repair it.
The driver transformer was quite hefty, that would be the piece that might have had the most effect on the sound.
Old 6th May 2012, 03:55 PM   #5
There is a schematic of a typical small germanium power amplifier here Germanium preamp .
You would add one stage to this to make a higher power amplifier. Note how the bias is adjusted and provided through the interstage coupling transformer. That is what I suspect gives the sound you are looking for. Since a matched pair of germanium power transistors are around $75.00 you might want to try using silicon for the driver and output stage.
The design there also shows transformer winding ratios! That should get you started.
Best of luck.
Old 24th May 2012, 09:00 PM   #6
Hello
I have the schematic for the baldwin amp.
email me at beercity@wi.twcbc.com
Roy
Old 25th May 2012, 08:35 PM   #7
evette is online now evette  Canada
Send a message via Yahoo to evette
output transistors are 2n2147 rca top hat series. Evette
Baldwin organ transformers no gas Tubes / Valves 7 21st March 2013 04:23 AM
germanium amplifier newmarko Solid State 6 6th January 2012 12:47 AM
Baldwin Transformer Swap wrenchone Tubes / Valves 10 18th November 2010 04:14 PM
Baldwin Iron wrenchone Tubes / Valves 16 5th January 2010 12:27 AM
Need for twin 5U4GB rectifiers in baldwin organ amplifier? RobCalm Tubes / Valves 8 24th July 2009 04:54 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
