Atleast any wires bearing current such as the speaker returns should in my opinion always go to the center point of the main storage caps and NOT to a secondary star.
My lafet amp does have a secondary star on the drive board where the signal grounds go along with some filter caps, and then a single wire from there to the center point of the main caps, there is no hum what so ever, u have to give it a signal to tell if its on or not.
This is the grounding scheme of the lafet amp: http://i.imgur.com/JDmSQ.png
That is what seem most logical to me.
So having signal and speaker ground sharing the same ground lead is the right way then ?
As in having smaller storage caps on each channel which center point is each channels speaker ground with a 10 ohm resistor between it and signal ground and then three leads per channel to the main psu, is this what your trying to say ?
If yes, then that for sure hum loudly as signal and speaker ground shares the same wires.
The speaker ground must have the same reference as the input signal, otherwise you are treating the difference between these two points as part of the signal. The arrangement shown in the link from post 11 ensures that ripple current feeding the second set of caps gets injected into the speakers. I assume this is not what you want.
http://i.imgur.com/fA390.png <-- but this just seems plain wrong, but it sounds on AndrewT like that is the right way.
But to me is just seems plain wrong.
Tekko, could you please try a quick sim experiment? With the circuit grounded as you show, could you place a few ohms in the lead going from PCB ground to the PS ground? Now could you do the same thing, but moving the speaker grounds to the PCB ground point?
I would do this, but I'm SPICE-challenged.
- Quick guide on Grounding
