Help with push pull opamps
Old 2nd May 2012, 12:57 PM   #1
dirkwright is offline dirkwright  United States
dirkwright's Avatar
Default Help with push pull opamps
Hello, I could use some help with this op amp with LSK170 inputs. I'm simulating this little op amp and it seems to be fine when used alone but when I parallel them for a push pull arrangement, it oscillates. The gain is the same for both circuits. I don't understand why the single version would be stable at low gain (6dB) whereas the double version is not. The double version is stable at higher gains. I've tried by pass caps around the feedback resistors, as well as other kinds of bypass caps and nothing is helping. Any input is appreciated.
Old 2nd May 2012, 01:19 PM   #2
Samuel Groner is offline Samuel Groner  Switzerland
This arrangement needs unity gain stable amplifiers. The reason is rather subtle, and in the hurry I don't think I'll be able to explain it well. Anyone?
Samuel
Old 2nd May 2012, 01:26 PM   #3
Tekko is offline Tekko
Banned
Why try discrete designs when there are opamps available that does unity gain just fine ?
The NE5532 is an excellent choice, its cheap and has very low THD and noise.
Old 2nd May 2012, 01:53 PM   #4
PChi is offline PChi  United Kingdom
My guess that the problem is due to the closed loop output impedance of the amplifiers increasing with frequency as the open loop gain falls.
The open loop output impedance of the amplifier is 27 ohms / 2 plus emitter resistances.
Any transient on the one of the outputs will be only partly attenuated by the open loop output impedance of the other amplifier which will then appear at it's input and be amplified. It must be just enough to sustain oscillation.
At higher gains the attenuation of the feedback is greater so no oscillation.
The single version is not very stable with some ringing at about 5 MHz at the input transition. It might be worth looking at the Bode plot of the open loop because there isn't much in the way of frequency compensation.
Old 2nd May 2012, 01:54 PM   #5
Frank Berry is offline Frank Berry  United States
Frank Berry's Avatar
I see that you are driving a 1k load on the single amp and a 150 ohm load on the double amp. Increase the load resistance on the double amp to 2k and measure the performance.
Frank
Old 2nd May 2012, 01:55 PM   #6
jcx is offline jcx  United States
why the lack of compensation C - how did you determine the amps are stable, with what margins, loads?
Old 2nd May 2012, 02:55 PM   #7
dirkwright's Avatar
Thanks for the suggestion. I just now tried that but it doesn't make a difference. I think it made it worse actually.
Old 2nd May 2012, 02:55 PM   #8
dirkwright's Avatar
Samuel
I figured that much, thanks. I guess the real question I'm asking is how to make a discrete op amp unity gain stable. It's too subtle for me to figure out on my own.
Old 2nd May 2012, 02:56 PM   #9
dirkwright's Avatar
Why sail a 40 foot boat across the Atlantic by yourself when you can fly there in 7 hours?
Old 2nd May 2012, 03:01 PM   #10
dirkwright's Avatar
Thank you! Now I remember! The open loop gain has to cross the 0 dB point before the phase shift reaches -180 degrees. As we can see in this plot, I don't have that in this circuit.
Help with push pull opampsHide this!Advertise here!
"Push-Pull" for push und "Push-Pull" for pull (like Gamnut) - whats the right name? tiefbassuebertr Solid State 70 15th August 2012 08:08 PM
Push-Pull vs Push-Pull-Parallel rsumperl Tubes / Valves 8 10th July 2012 05:34 PM
push pull chainenoble Subwoofers 17 28th June 2006 04:35 AM
modify parallel push-pull EL84 to single push-pull chungtat Tubes / Valves 12 3rd November 2005 11:25 PM
Double push-pull versus single push-pull jraraujo Tubes / Valves 19 19th October 2002 12:23 AM
