diyAB Amp  The "Honey Badger" build thread
Old 13th July 2012, 04:00 PM   #41
danielwritesbac is offline danielwritesbac  United States
danielwritesbac's Avatar
Default Bill of Materials (BOM) from DiyAudio.com store (link below)
Originally Posted by mattmcl View Post
Has anyone created a Mouser BOM for this amp yet? I started on it but I'm a bit of a noob and got confused on the types of resistors (ceramic, carbon, film, etc) that would be best.
The information is in the store.
Bill of Materials Spreadsheet
This can be opened with Excel, Excel Reader (free), Oxygen Office (free), Open Office (free) and more.
Or you can click on the attachment, which is a PDF
DIY Models & AppsClipNipperLM1875TDA7293Powerful Parallel TDA7293 kit ♦ My post has opinion.
Old 13th July 2012, 06:24 PM   #42
mattmcl is offline mattmcl  United States
For R43-R48 the BOM calls for noble resistors in the tolerance column. What does this mean?
Old 13th July 2012, 07:28 PM   #43
Noble is a brand name, like Vishay, Dale, etc. . . That entry needed to say "non inductive"
Mouser doesn't make it easy, but probably these:RS005R2200FE12 Vishay/Dale | Mouser
But, I think that OS actually used something like this: 280-CR5-0.22-RC Xicon | Mouser
The ordinary grade of little white 5 watt wirewound in values of 0.25 ohms and less (including our 0.22 ohms) are usually non-inductive with no extra effort for that feature and thus no extra price is necessary. However, the leads are inductive, and thus it seems that fitting nicely to the board is good to do.
Old 13th July 2012, 08:36 PM   #44
Variac is offline Variac  Costa Rica
diyAudio Editor
Variac's Avatar
any confirmation that this is true?
"The geek shall inherit the earth"
2017 Burning Amp is November 12 in S.F. Thread here on diyAudio:
http://www.diyaudio.com/forums/clubs...francisco.html
Old 14th July 2012, 01:20 PM   #45
Yes sir. Here is a little scrap of evidence in this Ohmmite datasheet. In wirewound construction, the shorter the element, the smaller the value, the lesser the inductance, so at the smallest of values there is insignificant inductance.
As far as the leads being inductive, that is merely wishful thinking because I hope they are good quality copper rather than some economy alloy. In either case it looks good to have the resistor fit so that the leads aren't long.
Old 15th July 2012, 03:43 PM   #46
dt2511 is offline dt2511
I'm in he same boat as mattmcl... trying to create a mouser BOM but am struggling. Has anyone done this yet? I've made it through the transistors and diodes, but am feeling a lower confidence level in selecting the right components from here on out. Anyone done this? I'd be greatly appreciative for any help...
Also, have found a few of the components aren't available at Mouser... specifically q10, q11, q12, q13 (2sa1381, 2sc3503)... found the substitutes in the build guide to be available however.
I've built a cmoy and a o2, looking to build understanding and take on a larger project... I'd appreciate any assistance! Thanks!
-dt2511
Old 16th July 2012, 04:48 PM   #47
dt, not sure if you saw this but I started a Google Docs spreadsheet with links to Mouser parts. There are still some holes, and I'm not sure if these are the best components but it's a start.
https://docs.google.com/spreadsheet/...U5vSUNoeHZlMXc
Old 16th July 2012, 04:53 PM   #48
Fantastic! i'll check it out.
Could we also perhaps ask for a hand from some of the more experienced members on the forum to vet this list? It'd provide a lot of value back to those building experience here to have a item-specific list for this project.
A little help please for us noobs?
Old 16th July 2012, 09:11 PM   #49
Default Mouser Search Trick (for broader search)
These might be listed as 2sa (japanese) or ksa (Fairchild) in the Mouser search. To blind the search to this difference omit either the 2 or the k. For example, search for sa1381 at Mouser and you will find it.
Old 16th July 2012, 09:11 PM   #50
Check out this thread on the chassis. Looks like they're working on adding part numbers to the BOM.
http://www.diyaudio.com/forums/site-...ml#post3094545
diyAB Amp  The "Honey Badger" build threadHide this!Advertise here!
diyAB Amp - The "Honey Badger" Variac Solid State 1808 Yesterday 05:11 AM
My LM3886 build thread CanAm Man Chip Amps 22 13th July 2012 08:48 AM
Ricci's dual B&C 21SW152 build thread. Josh Ricci Subwoofers 22 12th April 2010 10:39 PM
New Project Build Thread ryoung Multi-Way 5 19th April 2008 02:15 AM
Badger Badger Badger..... Mushroom !! 5th element Everything Else 15 20th September 2003 04:16 PM
