diyAB Amp  The "Honey Badger" build thread
Old 25th July 2013, 10:19 PM   #381
ostripper is offline ostripper  United States
ostripper's Avatar
Default Community input
I've identified from the forum some minor issues with layout.
Outlined in red circles below - (first pix)
#1 - D4-5 (D8-9) - output snubber diodes. Read that the fit is tight ...Badger holes are 1mm
I checked MR856G http://www.onsemi.com/pub_link/Collateral/MR850-D.PDF ...
1.3mm diameter ... oops.
#2 - "CRZ" jumper is masked.
#3 - C18-19 pads are masked.
#4 - jumperless design. The print side of the board shows jumpers , but these are actually plated through holes and run on the back layer (physically it is jumperless) ...easy fix ! I would however suggest real jumpers for the V+ trace as the plated through holes might be a current "bottleneck"(V2.2). A more permanent solution would be to increase the number of holes on the 2 points where the V+ trace crosses other traces. Sort of like the power and ground planes on a computer motherboard.
An example is below (pix 2).
These "bugs" are very minor and the version 2.3 board works and is even reviewed (no effect on proper operation). Just cosmetic and ease of construction updates.
Any other version 2.4 suggestions are welcome !!
OS
Wanderer - my travels.... Facebook - davyjones lockre -
Old 25th July 2013, 10:20 PM   #382
pthep is offline pthep  Canada
While on the subject of the AB amp bom, may I be allowed to take the discussion a couple of rungs further down the electronic evolutionary ladder. I noticed that the digikey address for R23 and R27 brings up 1/4 watt while the bom is calling for 1/2 watt. Is that an oversight or is it a non issue. Remember you are dealing with a strictly plug and play guy here.
Old 25th July 2013, 11:09 PM   #383
mattmcl is offline mattmcl  United States
I'm finding the holes for Q10, 11 and 12 to be too small as well.
Old 25th July 2013, 11:30 PM   #384
ostripper's Avatar
At rest , the VAS ( derived from P = E squared/R) = pulls just .005 watt through R23-27. Most OEM's (commercial amps) use 1/4w to 1/2w - overkill !! If the drivers (Q14-15)are loaded these resistors might see a little more. 1/4w will do !
I specified 1/4 watt for almost the whole Badger's small resistors as they are most common (radio shack - e waste), but 1/8w will do for most. I will refine the BOM with more choices. 1/8 watt devices might even look/fit better on the small signal stages (LTP/mirror). 1/4 watt's fit but slightly cover the screen printing .
R32-33 ,R36-50, and R53-54 are the only resistors that see .25w(1/4w) + ....
observe these ratings!!!
PS - R18/19 (the cascode divider ) sees .02w , most of the input stage LPT.mirror only .001 - .002w or less. We are QUITE derated !!
OS
Old 26th July 2013, 12:14 AM   #385
ostripper's Avatar
What version board (2.3?) I just fit a 2sc3503 , it's even loose !
In fact , the to-220 (slightly larger pins)even fits Q10-12 and Q13-15 .. all the medium sized transistor holes.
The only device that has a larger collector pin is the mje340/350 pair. For these ,I could use a sewing needle for the Q10 middle hole.
picture below shows everything.
OS
Old 26th July 2013, 02:41 AM   #386
OS
V 2.2
Old 26th July 2013, 03:18 AM   #387
First pic shows Mouser PN 512-KSA1381ESTU inserted, with original board holes drilled out to 1.5 mm. (I don't have a "before" pic.)
Second pic shows in red what size the original holes were (though the solder plates were visible.) In blue it shows the size they needed to be to fit this component.
Old 26th July 2013, 04:41 AM   #388
Variac is offline Variac  Costa Rica
diyAudio Editor
Variac's Avatar
looks like the pitch (how far apart the holes are) might be the problem, but OS's fit just fine.. ?
Maybe we'll make these in red so people know that they're the latest. .
It would be nice to have a Digi-key BOM too at some point. I deal with them a lot. Not a big deal though
Athough if the BOM is in the right spreadsheet format the whole order just sliiiiiides in..
Although Mouser prob has the same thing?
"The geek shall inherit the earth"
2017 Burning Amp is November 12 in S.F. Thread here on diyAudio:
http://www.diyaudio.com/forums/clubs...francisco.html
Old 26th July 2013, 04:46 AM   #389
ostripper's Avatar
wow 1.5mm !! That's big diode territory !
http://www.classiccmp.org/rtellason/...ta/ksa1381.pdf
States .75mm , I set the V2.2 to .82mm for all the to-126's (below 1). I do not know how this happened as I submitted the correct drilling size. I don't know how they got to V2.3 (the holes are right on these) , but (at least)on the V2.2 sprint file , it was right. STRANGE !!
Just about have V2.4 done (below 2). I'm using parts on hand,a V2.3 board, and datasheets to tweak the holes.
OS
Old 26th July 2013, 04:57 AM   #390
ostripper's Avatar
Yes , Mouser has the spreadsheet BOM conversion ... http://www.mouser.com/BOMHelp/
Variac , If you could give the mounting hole spacings and any other requests
(Maybe a real badger on the board) .
I'm doing this on the build thread as this is where the information is (builders -holes - spacings - problems?).
On the discussion thread - component options , smaller input stage resistors (1/8 watt) , fets !! I'll do that before the final BOM update - spreadsheet stage.
OS
diyAB Amp  The "Honey Badger" build threadHide this!Advertise here!
diyAB Amp - The "Honey Badger" Variac Solid State 1835 4th June 2018 10:31 AM
My LM3886 build thread CanAm Man Chip Amps 22 13th July 2012 07:48 AM
Ricci's dual B&C 21SW152 build thread. Josh Ricci Subwoofers 22 12th April 2010 09:39 PM
New Project Build Thread ryoung Multi-Way 5 19th April 2008 01:15 AM
Badger Badger Badger..... Mushroom !! 5th element Everything Else 15 20th September 2003 03:16 PM
