diyAB Amp The "Honey Badger" build thread - Page 36 - diyAudio
Old 6th July 2013, 01:23 AM   #351
HoneyBadger's Avatar
@hotrodmaniac
You the best! This is why I love this forum - don't know much but people are always helpful enough for me to learn
Old 6th July 2013, 03:18 AM   #352
ByronInPortland's Avatar
Originally Posted by HoneyBadger View Post
Does anyone know the orientation of the zener diode? I can't find documentation for this and it is not clear to an amateur from the circuit diagram.
See post #291
Old 8th July 2013, 11:39 PM   #353
I see there are no solder pads for the add-in leads. Should i just run wire in a loop and twist or what?
Old 9th July 2013, 03:51 AM   #354
RINNAV is offline RINNAV  United States
Any thoughts on using these CADDOCK resistors in place of the hard to find NOBLE resistors (R43-R48)? The wattage handling specifics are way overkill but without a heat sink may be worth a try.
http://www.caddock.com/Online_catalo...000_Series.pdf
Old 9th July 2013, 06:23 PM   #355
On Rinnav's note, what about a wirewound? Why is the NOBLE resistor recommended?
Old 9th July 2013, 07:08 PM   #356
Stormrider's Avatar
Send a message via AIM to Stormrider Send a message via MSN to Stormrider
Probably just because that's what the PCB was designed for. A typical axial 5W ceramic wirewound will work, but will have to be stood on end.
AJ
Old 9th July 2013, 07:17 PM   #357
I noticed the diodes being stood on end as well... I can only imagine this is for heat dissipation. Is it completely necessary? I imagine the diodes get hotter on one end but the resistors?
Any ideas on the previous post for the leads?
-Phil
Old 9th July 2013, 09:56 PM   #358
My 5w ceramics weren't stood on their ends.
Old 9th July 2013, 09:59 PM   #359
Just use whatever 5w ones you can get. 5w ceramics are ok. I found the main thing to change the Sonics in this amp was to try different types/brands of input cap.
Old 9th July 2013, 10:37 PM   #360
Amazon.com: Amico 5 x 5W 0.22 Ohm 0.22R 5% Radial Ceramic Cement Power Resistors: Everything Else
diyAB Amp - The "Honey Badger" Variac Solid State 1710 Today 03:56 AM
My LM3886 build thread CanAm Man Chip Amps 22 13th July 2012 07:48 AM
Ricci's dual B&C 21SW152 build thread. Josh Ricci Subwoofers 22 12th April 2010 09:39 PM
New Project Build Thread ryoung Multi-Way 5 19th April 2008 01:15 AM
Badger Badger Badger..... Mushroom !! 5th element Everything Else 15 20th September 2003 03:16 PM
Copyright 1999-2017 diyAudio
