diyAB Amp The "Honey Badger" build thread - Page 33 - diyAudio
Old 12th June 2013, 09:22 AM   #321
That would be roughly 100W into 4ohms speaker.
I seem to recall you use 4ohms.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 12th June 2013, 05:46 PM   #322
still4given's Avatar
I do for some of my stuff. My Nearfields are 4ohms and my JBL 4425 are 6ohm.
My experience is that with good speakers, 100 watts is VERY LOUD! If I use both trannies, I'll have +/- 39V at 10A. High bias should be no problem. I don't plan on using this for PA work.
Old 12th June 2013, 10:03 PM   #323
ncg2013 is offline ncg2013  United Kingdom
Send a message via Skype™ to ncg2013
Default Double decker toroids
Hi All
To save space I am thinking of mounting two toroids one on top of the other, does anyone know if this will present a problem?
Old 21st June 2013, 12:57 PM   #324
TonyTecson's Avatar
no problem, just get a longer bolt....
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 27th June 2013, 01:20 AM   #325
pthep is offline pthep  Canada
First post on this forum. I have aquired the p-diyab-2v20 boards from the store, plus downloaded the build guide and bom. I am about to begin sourcing the required components to get on with this project. I have been reading through the 2 major threads and noticed there is a lot of discusion about certain part types and values etc, most of which, I admit I don't understand. My major concern is that if I follow the published BOM is that going to give me a satisfactory result? An area where an option is available, namely D3, what is that going to acheive? Also the G1 and G2 on the schematic, different potential? Forgive me for being technically inept when it comes to electronics, its not my first calling, but that doesn't dampen the interest.
Old 28th June 2013, 01:24 AM   #326
ByronInPortland's Avatar
Welcome aboard pthep.
I built my HB using the published BOM exactly, and am very happy with the sound. One catch is that the holes for D3/R18 are too small for the recommended D3. I was able to widen them with a 1/32" drill bit on a Dremmel.
Also, the recommended power resistors (R43 to R48) are no longer available, and no one (that I know of) has been able to find a replacement with the same lead spacing. So I mounted wirewound resistors standing upright, which is what I think others have done.
Have fun!
Old 28th June 2013, 01:35 AM   #327
TonyTecson's Avatar
here's mine...
Old 28th June 2013, 01:47 AM   #328
To answer your other questions:
I didn't understand what is gained by the "zener reference design" over the "Luxman" way either. But the Luxman design was described as "crude" in the build guide, so I guessed it must be somehow inferior.
You can follow the trace from the ground-end of D1, D2 and R4 (G2) all the way to the star ground (G1) so they're not at different potentials. I really can't guess why they are written at G1 and G2 on the schematic.
Old 28th June 2013, 03:37 AM   #329
TonyTecson's Avatar
a ground is a ground is a ground, and a ground, should all have zero voltage...
regarding r18/d3, i pressolderd the resistor to the zener, clipped leads and soldered the combination into the board...
i had to enlarge some of the holes to facilitate lead insertions, a pcb drill came in handy...
Old 28th June 2013, 06:46 AM   #330
Tony,
Are these boards available for sale from this website somewhere or did you do those boards yourself ? If so have you got a link ?
The link at #305 is dead to me.
diyAB Amp - The "Honey Badger" Variac Solid State 1728 28th May 2017 05:47 PM
My LM3886 build thread CanAm Man Chip Amps 22 13th July 2012 07:48 AM
Ricci's dual B&C 21SW152 build thread. Josh Ricci Subwoofers 22 12th April 2010 09:39 PM
New Project Build Thread ryoung Multi-Way 5 19th April 2008 01:15 AM
Badger Badger Badger..... Mushroom !! 5th element Everything Else 15 20th September 2003 03:16 PM
Copyright 1999-2017 diyAudio
