diyAB Amp  The "Honey Badger" build thread
Old 14th May 2018, 10:51 PM   #3051
carlmart is offline carlmart  Brazil
Any chance to get that thread but in English?
Old 15th May 2018, 03:45 AM   #3052
janusz is offline janusz  Australia
I did a few HB simulations with different transistors and results notably depended on the choice of transistors or rather the accuracy of their models. Just take OnSemi's njl0xxx series and njl1302/3281 and there are even greater differences between these and mjl1302/3281 and their Cordell versions. Which models are correct???
cheers,
Old 25th May 2018, 08:37 PM   #3053
Kay Pirinha is offline Kay Pirinha  Germany
Kay Pirinha's Avatar
Received a notification by Mouser today that ON Semi has announced end of life for the BAV21 diode.
Best Regards!
"Bless you, Sister. May all your sons be bishops." (Brendan Behan)
Old 26th May 2018, 10:44 AM   #3054
mbrennwa is offline mbrennwa  Switzerland
mbrennwa's Avatar
How about Google translate? It's not perfect, but hopefully good enough.
[ audioroot.net | hifibau.ch ]
Old 28th May 2018, 05:07 PM   #3055
akimmet is offline akimmet  United States
Best Regards!
Not really a big deal since there are still other manufacturers making BAV21.
Old 28th May 2018, 09:09 PM   #3056
tonza75 is offline tonza75  Europe
The orginal did not use one there are better smd of course.
Old 5th June 2018, 01:54 PM   #3057
sasmit is offline sasmit  India
Send a message via Yahoo to sasmit
Default honey badger power supply question
can we run the honey badger off a 25-0-25 trafo ?
whats the minimum that we can run it off?
Old 7th June 2018, 09:28 AM   #3058
Have a look at the building guide!
Best regards!
Old 14th June 2018, 05:34 PM   #3059
nfsgame is offline nfsgame
What about using 1N459A instead? Lower Vr (100nA on the BAV21 vs. 25nA on the 1N459A) what should be better for this use (lower distorsion). Unfortunately it got a slower recovery time. How would this affect on circuit?
diyAB Amp  The "Honey Badger" build threadHide this!Advertise here!
diyAB Amp - The "Honey Badger" Variac Solid State 1846 Today 09:04 AM
My LM3886 build thread CanAm Man Chip Amps 22 13th July 2012 07:48 AM
Ricci's dual B&C 21SW152 build thread. Josh Ricci Subwoofers 22 12th April 2010 09:39 PM
New Project Build Thread ryoung Multi-Way 5 19th April 2008 01:15 AM
Badger Badger Badger..... Mushroom !! 5th element Everything Else 15 20th September 2003 03:16 PM
