diyAB Amp  The "Honey Badger" build thread
Old 7th February 2018, 03:35 PM   #3011
R.I.P.
Originally Posted by medi57 View Post
Will it hurt? ...........
Yes, both your pocket and the design.
A higher voltage from the PSU will result in a higher dissipation in all devices passing current from those rails.
That means selecting devices that can tolerate the extra dissipation.
And now that you have these higher dissipations you need bigger heatsinks to get rid of that heat.
regards Andrew T.
Old 7th February 2018, 04:01 PM   #3012
prasi is offline prasi  India
prasi's Avatar
If its just a matter of device dissipation and Heatsink, he can do the following
1. use use MJL devices
2. use a speed limited fan, xrk uses them often.
This could just save heavy expenses.
But I wonder if its just the devices and heatsinks that need attention.
My revamped site https://sites.google.com/site/analogdesign1234/
Old 7th February 2018, 04:15 PM   #3013
medi57 is offline medi57
45 it is!
Old 11th February 2018, 08:17 AM   #3014
stuartmp is offline stuartmp  Australia
Hi All. I was just wondering if there is a more detailed description of how this circuit works. I am fine with 90% of it. I just don't see exactly how the output of the differantial pair drives the vas. It looks like the output of the current mirror (top left of the schematic) is attached to two pnp transistors which form a VAS cascode (top center of the schematic) which is then supplying the bias current for the vbe multiplier which drives the output transistors.
If someone can provide me so more details or point me to a older post discussing this that would be awesome.
Cheers
Stuart
Old 24th February 2018, 05:42 PM   #3015
rock12 is offline rock12  United States
I am building th hb as designed and need to know fuse sizes at the switch in the 4u case and on the circuit board
Old 24th February 2018, 06:03 PM   #3016
mbrennwa is offline mbrennwa  Switzerland
mbrennwa's Avatar
The fuses on the board are 5 x 20 mm.
The size of the fuses in the IEC/switch assembly depend on the IEC/switch you use (but they are often also 5 x 20 mm).
[ audioroot.net | hifibau.ch ]
Old 24th February 2018, 06:55 PM   #3017
prasi's Avatar
use slow blow 5 amp fuse on mains 5mm x 20mm along with a matching case thats panel mounted and easy to replace from outside.
on the pcb , use 7-8 amps fast blow of 5mm x 20mm size on amp pcb.
Old 25th February 2018, 10:58 AM   #3018
thanks prasi I guess I stated the question poorly I was after amperage I am wondering how we deduce the needed ampereg the mains fuse supplies the universal power supply with the an 8445 tranny for a power supply of 62 volts to the hb amp prasi recommends 5amp at the mains and 7 amps at the hb board this seems backward to me but sometimes my logic is bad
Old 25th February 2018, 11:25 AM   #3019
jwilhelm is offline jwilhelm  Canada
The transformer manufacturer normally will recommend a maximum input current for their products. If not you can calculate it by dividing the VA rating of the transformer by your line voltage. Normal industrial practice is to multiply this number by 125% for inrush, but this isn't really required with a good soft start circuit. Add any other current draws in your amplifier (control transformers, ect) and you have your fuse rating.
Rail current will be much higher than mains current. The mains voltage is stepped down increasing current available, plus there is a considerable current reserve available in the supply capacitor bank. If you install too light of a rail fuse you will get distortion resembling clipping at high output, and you will see some discolouration and deformation of the fuse element as it starts to melt on current peaks, then re-solidifies (fuse distortion). I use a separate output stage over-current protection and use 15A rail fuses normally in my builds.
https://www.vzaudio.com/
Old 6th March 2018, 10:02 PM   #3020
Silvi is offline Silvi  Malta
If the Honey Badger had to be powered with an smps would it worsen its performance? SMPS can give big power being smaller and lighter. Output capacitance would not have to be so abundant either as these will recover around a 1000 times faster than a normal 50Hz transformer
diyAB Amp  The "Honey Badger" build threadHide this!Advertise here!
diyAB Amp - The "Honey Badger" Variac Solid State 1835 4th June 2018 10:31 AM
My LM3886 build thread CanAm Man Chip Amps 22 13th July 2012 07:48 AM
Ricci's dual B&C 21SW152 build thread. Josh Ricci Subwoofers 22 12th April 2010 09:39 PM
New Project Build Thread ryoung Multi-Way 5 19th April 2008 01:15 AM
Badger Badger Badger..... Mushroom !! 5th element Everything Else 15 20th September 2003 03:16 PM
