diyAB Amp  The "Honey Badger" build thread
Old 2nd January 2018, 10:57 AM   #2971
Johno is offline Johno  Australia
Johno's Avatar
Default R23
I am still using R23 = 47R. If it is taken too low it can affect stability.
Old 2nd January 2018, 04:06 PM   #2972
thimios is offline thimios  Greece
Originally Posted by anatech View Post
That journey may have been made for his health. Not to mention the fact that he needs to clear his mind.
He's a really good guy and deserves to recover fully. Let's hope that happens.
-Chris
I worry for him.
Nothing posted for a long.
Old 2nd January 2018, 05:32 PM   #2973
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Thank you...
I see that Rod uses no resistor here: 60-80W Power Amplifier
And Bigun does neither here: TGM8 - an amplifier based on Rod Elliot P3a
That is why I wondered about this resistor..... maybe we need lower gain in this VAS ??
RC
Old 2nd January 2018, 05:34 PM   #2974
nhinstruments
RCruz's Avatar
Originally Posted by thimios View Post
I worry for him.
Hope everything is allright
RC
Old 2nd January 2018, 06:01 PM   #2975
R.I.P.
Originally Posted by RCruz View Post
Thank you...
Adding in VAS degeneration reduces stage gain and thus reduces open loop gain.
This will have a direct effect on the stability margins.
Removing the degeneration from an amplifier that has been designed to have adequate, but not excessive stability margins will perform differently and may shown signs of instability, or worse, complete oscillation.
The same argument applies to the Input LTP degeneration.
regards Andrew T.
Old 2nd January 2018, 07:23 PM   #2976
nhinstruments
RCruz's Avatar
Thank you Andrew.
Now I fully understand the issue.
I would also appreciate your comments about this other issue: Assemblage Power Amp
Best
Ricardo
RC
Old 4th January 2018, 08:37 PM   #2977
audiorasp is offline audiorasp
Default LC cap
I'm curious if many builders have added the lead compensation capacitor and if they consider it a "necessary" option. I've looked at the comments in the build guide but would like to know what other builders think.
Old 4th January 2018, 09:11 PM   #2978
helitim is offline helitim  Canada
I believe the more popular opinion is to leave it out . I'm leaving it out of my build based on others experiences .
Edit: There is a discussion in this thread, or the general badger Thread. You could search the thread for LC, or lead compensation if you didn't want to sift through the 500-ish pages
Old 4th January 2018, 09:56 PM   #2979
mbrennwa is offline mbrennwa  Switzerland
mbrennwa's Avatar
I have tried with the LC cap, using different values. It sounded best to my ears without the LC cap.
[ audioroot.net | hifibau.ch ]
Old 4th January 2018, 10:11 PM   #2980
helitim, mbrennwa, thanks.
I will search that general discussion thread also.
diyAB Amp  The "Honey Badger" build threadHide this!Advertise here!
diyAB Amp - The "Honey Badger" Variac Solid State 1835 4th June 2018 10:31 AM
My LM3886 build thread CanAm Man Chip Amps 22 13th July 2012 07:48 AM
Ricci's dual B&C 21SW152 build thread. Josh Ricci Subwoofers 22 12th April 2010 09:39 PM
New Project Build Thread ryoung Multi-Way 5 19th April 2008 01:15 AM
Badger Badger Badger..... Mushroom !! 5th element Everything Else 15 20th September 2003 03:16 PM
