diyAB Amp  The "Honey Badger" build thread
Old 8th February 2013, 01:58 PM   #221
chunek is offline chunek  Singapore
Hi kclusa@yahoo.co, I have the same problem as you. If you have driller, you can get 0.8 to 1.2 mm drill bits to enlarge the hole. Just need to ensure that hole is not a via hole else you need to solder the lead on both side of tracks.
chunek!
Old 8th February 2013, 03:36 PM   #222
ncg2013 is offline ncg2013  United Kingdom
Originally Posted by kclusa@yahoo.co View Post
0) I am assuming you are using the PCB supplied by the store. Otherwise, ignore all of my comment.
1) For D3, I had trouble fitting 1W diode through the PCB hole. I ended up with using resistor approach.
2) For 0.22R resistor, it is not the same package type as build guide shows. It will work if you don't mind unstable resistor mounting. I did the same thing as you, later on, switch all 12 to the smaller kind.
3) Those 220uF and 470uF Nichicon KW series capacitors are audio grade. You may or may not need 0.1uF capacitor. Also check whether the hole is large enough for those audio grade cap. Their leg maybe very thick in diameter. If I were you and prefer Nichicon, I will also purchase inexpensive Nichicon VR as a back up. They will fit although only for general purpose.
I was worried about components not fitting but I thought I could drill them if they don't - I have a dremmel and small bits so shouldn't be a problem. I shall check 0.22R resister and see what else is available.
Old 8th February 2013, 03:38 PM   #223
How do the rest of the components stack up with yours? Have you finished yet? What did you use for Q5/6?
Old 8th February 2013, 04:35 PM   #224
kclusa@yahoo.co is offline kclusa@yahoo.co  United States
Default Re : Mouser BOM
I was using the component from the XLS file published very early in this forum. Most of the capacitor are Panasonic FC series.
For Q6, I m just using KSA992.
I finished about few weeks ago. And updated my observation on this site. Please see #195 for detailed info and how I finalize the tuning. For whole system tuning, your bulk decoupling capacitor also play an important role.
I am sure distortion is important for most of the people. However, after the distortion number down to less than 1%, tuning the amp for my taste is as important as distortion. After all, my major application of this amp is not feeding 400Hz square wave and observe on the scope.
That is just my opinion. Any feedback is welcome.
Lou
Old 11th February 2013, 09:28 AM   #225
Anyone have some suggestions for the power supply caps? I am using the universal power supply PCB. I wanted to max out the capacitors C1 to C8 with 15000uf at 80v but I cannot find the right size or voltage anywhere.
I assume this gives me 150000uf per channel.
Old 11th February 2013, 01:10 PM   #226
Default Re : Bulk Capacitor
More capacitor does not necessarily mean better sound.
I would start with 20000uF per rail, tune it up.
If not satisfied, than adding one pair at a time.
It is O.K. to buy 8, left over can be used for next project anyway.
Old 11th February 2013, 01:29 PM   #227
If I was only going to use 20000uf per rail (assume 2 x 10000uf) then which capacitors should these be? Trying to figure this out from the schematic.
My guess would be C3, C8 and C1, C6. I take it leaving the other caps out would not effect the PSU?
Old 11th February 2013, 01:43 PM   #228
You probably also need to short R1 - R8 assuming you are not using PI filter
Old 11th February 2013, 01:46 PM   #229
yep, going to short them.
Old 22nd February 2013, 04:26 PM   #230
ByronInPortland is offline ByronInPortland  United States
ByronInPortland's Avatar
Default I took the plunge!
I've wanted to build this amplifier for a while now. Well, over the last few days I made the commitment. I ordered:
  • a pair of Honey Badger boards
  • a pair of diyAudio power supply boards
  • The diyAudio speaker protection and the softstart boards
  • the back panel parts kit
  • the 5U value chassis (I can drill & tap holes myself)
  • an Antek AN 8435 (800VA, 35V secondaries)
  • An order from Mouser with 79 line items.
I can thank our recent snowstorm which kept me stranded at home all day yesterday. I spent most of yesterday choosing parts, and I had already spent hours on this task over the past few weeks! Much of the advice I found in this forum was very helpful. Thank you, all of you advice-givers!
I look forward to posting my progress and results.
-Byron
diyAB Amp  The "Honey Badger" build threadHide this!Advertise here!
diyAB Amp - The "Honey Badger" Variac Solid State 1808 16th January 2018 05:11 AM
My LM3886 build thread CanAm Man Chip Amps 22 13th July 2012 08:48 AM
Ricci's dual B&C 21SW152 build thread. Josh Ricci Subwoofers 22 12th April 2010 10:39 PM
New Project Build Thread ryoung Multi-Way 5 19th April 2008 02:15 AM
Badger Badger Badger..... Mushroom !! 5th element Everything Else 15 20th September 2003 04:16 PM
