diyAB Amp The "Honey Badger" build thread - Page 17 - diyAudio
Old 17th January 2013, 08:26 AM   #161
Art M is online now Art M  United States
"The input cap should be high quality polystyrene ,very stable over time".
Can somebody give me a hint as to where I can find a 4.7uF Polystyrene dielectric capacitor? Or do I just misunderstand what cap is being discussed ?
Old 17th January 2013, 11:15 AM   #162
Originally Posted by Art M View Post
............4.7uF Polystyrene dielectric capacitor? ...............
I have never seen one, but I would not be surprised to find it as big as a box of Cornflakes. And maybe cost the same as a small automobile.
4.7uF can be MKP, MKT, FKP, FKT, or electrolytic. If you read Marsh and others you will find many other viable options.
If going electrolytic to save space and money then use two 10uF bipolar electrolytics in series for an effective 5uF.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 17th January 2013, 02:29 PM   #163
ncg2013 is offline ncg2013  United Kingdom
Send a message via Skype™ to ncg2013
OS, thanks for those explanations, just a couple more.
Will 40-0-40VDC give a power output into 4R of about 114W?
What is the formula for working out the rail voltage from the transformer secondary voltage?
Old 18th January 2013, 10:06 AM   #164
Originally Posted by ncg2013 View Post
...................Will 40-0-40VDC give a power output into 4R of about 114W? ...........
more like 120W to 160W into 4r0.
regards Andrew T.
Old 18th January 2013, 10:13 AM   #165
Andrew, thanks for that.
I wanted to be at the top end of that, about 150W. Obviously if I up the supply to 45v it will do it, but you mentioned previously that this is not good for 4ohm loads. what else can be done?
Old 18th January 2013, 10:34 AM   #166
What transformers are available?
That determines the PSU voltage.
regards Andrew T.
Old 18th January 2013, 10:39 AM   #167
Any transformer I have not bought one yet...
Old 18th January 2013, 10:42 AM   #168
transformer voltages 22, 25, 28, 30, 35 & 40Vac are generally available, although few if any manufacturers offer any more than three voltage options from that range.
regards Andrew T.
Old 18th January 2013, 10:54 AM   #169
You mentioned that I could get between 120w and 160W, if I use a 40Vac transformer what else can I do to make sure it produces 150W into a 4R load? If anything!
Old 18th January 2013, 11:31 AM   #170
40Vdc is not the same as 40Vac.
40Vac+40Vac can achieve 170W into 8r0 and over 300W into 4r0.
I have reported these results some 5 or more years ago in the Leach Thread.
regards Andrew T.
diyAB Amp - The "Honey Badger" Variac Solid State 1706 8th February 2017 09:45 AM
My LM3886 build thread CanAm Man Chip Amps 22 13th July 2012 08:48 AM
Ricci's dual B&C 21SW152 build thread. Josh Ricci Subwoofers 22 12th April 2010 10:39 PM
New Project Build Thread ryoung Multi-Way 5 19th April 2008 02:15 AM
Badger Badger Badger..... Mushroom !! 5th element Everything Else 15 20th September 2003 04:16 PM
Copyright 1999-2017 diyAudio
