I have just had the pleasure of repairing a friends 18 year old MF A1-X class A amp that has been out of commision for a few years. The 0.47 Ohm PSU filter resistors were burnt out. I replaced them and viola - working again.
I looked at Mark Hennesy's excellent page about this amplifer for the circuits, and must admit I winced - that volume control, the double feedback network, 'lytics everywhere. Well, those are my engineering prejudices. Reality is a bit different. Hooked up to my B&W 702's this little amp blows the Marantz PM7000 away - very smooth sweet sound and I am most impressed. Of course its no match for my Ovation amp but that is a 250W monster. I could happily live with this for a second amp for jazz and light chamber music. Heatsink temperature after about 40 minutes was 55C BTW (measured with a gun type IR thermometer) I real little classic - awsome! |
#2 |
I've not seen inside these before, thanks for the pics, Bonsai.
What are the thick, square sections - heatsink extrusions?. Even at 2 x 10W, it must run hot throughout but that's nothing new for MF. Are you contemplating a 250W version for a shoot-out?
regards |
#3 |
Hi Ian,
Yes, that's the A1 sitting on top of the 250W Ovation. That's got 5 pairs of 21193/21194 biased up at around 120mA per pair, so it's got a few watts of class A! The A1 has an inverted U section inside and the output devices are mounted on this. The inverted U section is then coupled to the top plate with some Heatsinks compound and 3 screws. Surprisingly good sound for such a little amp, and especially the idiosyncratic line stage. I returned the amp to the owner today an he was pretty pleased. |
#4 | |
5pr @ 120mA bias gives a push pull output stage a maximum ClassA output of just under 1.2Apk. I would finish the sentence from above with "so it's got 2.3Apk of ClassA". That seems unambiguous and informative. |
#5 |
Well...Audio Amplifier Design and Circuits | hifisonix.com has a bit more info for others if Bonsai doesn't object.
'Wonder how it sounds (or not) since the big bang and dash for SSRs?
regards |
#6 |
I doubled the ClassA current twice.
I can't do that. It should have said "so it's got 1.1Apk of ClassA". |
#7 |
It's fixed and singing again Ian.
The cause of my mishap: two 2 pin mains sockets next to each other. One wired for 110 the other for 220. That's why it fried up. I found out because I have a 1kva transformer that I wired up to take in 100vac in Japan and give me 220vac out. Well, I tired the same trick here and the transformer buzzed and the mains tripped. I checked my wiring, it was ok, checked the voltage on the input and it was 218vac. Luckily, after I repaired my amp, I had plugged it into the LHS socket. The CD player is universal mains input, and this was plugged into the 220vac socket, so I never suspected. BTW there are four 220 sockets in the house. I would have thought they would have at least used a different type of socket. |
#8 | |
Just curious, what is it about that volume control ?
AmpsLab.com |
#9 |
Andrew, c. 600mA bias in total is indeed just under 1.2A in class A.
#10 |
So the question from my viewpoint is:
Does stating the ClassA current provide more information than stating the ClassA power? Which way would do better service to the DIYaudio community? |
| Problem with my Musical Fidelity A1-X | dado1979 | Solid State | 39 | 6th February 2012 07:19 PM |
| Musical Fidelity A1 bias | tubeing | Solid State | 7 | 24th June 2010 11:29 AM |
| Musical Fidelity A1 Improvements | juluska | Solid State | 17 | 8th February 2010 12:37 PM |
| Musical Fidelity X-A1 Upgrade | ChrisR1983 | Solid State | 1 | 28th August 2009 11:16 AM |
| Musical Fidelity A1 Heatsink | Assesears | Everything Else | 5 | 17th February 2004 07:45 AM |
